- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
StreetfighterKz wrote:
kaw-a-holic wrote: That would be great I am using 1998 Suzuki GSXR 750 Showa forks.
Double check your years before spending $$.. '96+ Gsxr750's have a 25mm axle, no speedo drive and flat brake rotors. I think you have a '93-95 Gsxr750 front end.
Later, Doug
My axle is 28mm and does have a speedo drive. What do you mean by flat brake rotors?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- kaw-a-holic
StreetfighterKz wrote: Just went back through your thread. Measure the OD of the upper fork tubes at the top and bottom clamps. It's possible you have a Gsxr1100 front end. The Gsxr750 measures 50/54 and the Gsxr1100 is 52/56 I think.
Later, Doug
50/54
Jon
1977 KZ1000a1
Mesa, AZ
- StreetfighterKz
- Thank you received: 117
Later, Doug
Are you measuring the axle at bearing surface? It should be 20mm there. The end with the nut is bigger than the main axle shaft. As for flat rotors...there is no offset ie no dish to them. The braking surface is in the same plane as the mounting surface.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- kaw-a-holic
Later, Doug
Later, Doug
I measured the axle right in front of the rotor. Rotors are off set.
Jon
1977 KZ1000a1
Mesa, AZ
- StreetfighterKz
Later, Doug
1989 Vmax
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- StreetfighterKz
kaw-a-holic wrote: Thanks for the info, at closer look I see you are correct.
N/P. I just don't want anyone to spend money on the wrong parts. I've done it too often for me to let someone else do it if it can be helped.
Later, Doug
1989 Vmax
- davido
- Thank you received: 292
He can do any model/year. He needs the top caps with all the gubbins in them,or the complete fork. He machines out the gubbins,threads it all up and replaces it into a new,lengthened section. So keeping all the original spacing. You adjust the forks in the same way only with a longer screwdriver/socket. He also fits a cap to top everything off.
He can do whatever length you want. He can go to 12cm which is very long and reckons most streetfighters go to between 5cm and 8cm.Also be aware that sometimes the fork tapers a bit around the bottom yoke which can limit how much it can be raised.
He sent me a link to his webpage/site/whatever.
www.vmax.tk/
(My Dutch isnt so good,so Im relying on google translate but I think that pretty much covers it.)
For me,I like the idea.though Im not going to make a decision until I have the bike back and make some proper measurements.(sometime this week,I hope).
If youre interested in this,you can contact the guy direct,theres an email address on his site (Im sure he speaks English,most Dutch people do). Or if you are ok to wait and see how it goes with mine (if I go for it) I can give you a 'Happy' or 'Not Happy'.and take it from there.
He sent a couple more photos .Looks like a before and after.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 2740
- Thank you received: 2061
kaw-a-holic wrote: I contacted Les Holt about making a dropped triple upper and lower to get some offset back as well. The fork extentions concern me. They seem like a likely weak spot. I am tempted to go the cheaper route but have not really spared any expense to this point other than going with cheap rear shocks.
Do it right Jon
You will ride without fear knowing its done right.
Those extensions look nice , but I am having a hard time trusting them in my mind.
