- Thank you received: 2740
Phoenix Fighter
- kaw-a-holic
- Thank you received: 249
swest wrote: Maybe we can open up the west coast and points East for the relay.
I think we need to put together a SW rally like they did in CO. When the bike is running I will start a post.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- kaw-a-holic
missionkz wrote: My preference would be CO but I'd be up for anything in the four corner states.
Good to know. I don't want to clutter up my project thread discussing it here. I will start a rally thread tonight. As long as it's within an 8-10 hour ride from Phoenix, AZ I'm down. Temp and possible weather needs to be considered.
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
1. Scored a set of 110° Webcams and am wondering if I should install them now or wait. Currently I have Andrews 1X cams installed. 1075 Wiseco 10:1.25 pistons, Heavier duty springs that will handle performance cams. Mikuni RS36 flat slide carbs.
Adrews 1X cam Specs
110° Webcam Specs
Second, due to my choice of location for the oil cooler I may need to add a fan this summer. I would like to control it with a thermostat switch. The ones I am finding turn on @ 180° and off @ 165°. That seems a bit cold for the bike, great for a cage. What temperature range should I be looking for?
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Need feed back on two items.
1. Scored a set of 110° Web camshafts and am wondering if I should install them now or wait. Currently I have Andrews 1X cams installed. 1075 Wiseco 10:1.25 pistons, Heavier duty springs that will handle performance cams. Mikuni RS36 flat slide carbs.
As we all know cam bearings are expensive. If I have to replace bearings to do a swap after the engine has run, I would rather do it now. It also appears that the Web Cams are not drop ins. Will I need adjustable timing gears?
Adrews 1X cam Specs
Lift Duration Timing TDC CL Angle Lash
In .344 260 24/36 .104 106 .004
Ex .344 260 56/24 .104 106 .004
110° Web cam Specs
In. .395 256 22/56 106 .00 @ 0.050 Inches Of Valve Lift
Ex. .395 256 54/20 108 .00 @ 0.050 Inches Of Valve Lift
Jon
1977 KZ1000a1
Mesa, AZ
- les holt
- Thank you received: 288
Les
- kaw-a-holic
les holt wrote: 110's are supposed to be drop ins but I've seen 2 such setups now with spit shims. 1 was a properly done setup, other, can't say with certainty but the 1st one, made me decide it's not worth the gamble, go shim under for peace of mind. it's more difficult to do a maintenance job on the lash but don't let that sway you away from them. good street cams
Les
Wholly ghosts! I have not seen you forever Les. So Shim under? How am I supposed to convert it? Is there a kit? I have heard of this before but have never found the detailed bits to get it done.
Jon
1977 KZ1000a1
Mesa, AZ
