- Thank you received: 797
Phoenix Fighter
that frame brace kit welded in awesome :evil: !
whoever welded it in done an outstanding job .
header looks very sweet.
your moving right along,keep up the good work sir!
- spdygon
- Thank you received: 117
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
- Motor Head
- Thank you received: 391
- kaw-a-holic
- Thank you received: 249
Motor Head wrote: As far as the oil cooler mounting location. You want that out in the air flow, or run a couple of electric fans right on it, possibly a cowl to direct the air flow. Most would mount right out front at the front down tubes of the frame. Maybe not as nice as hiding it, but you need the cooler to reduce temps, which is by exchanging with air, lots of it.
I agree with you but I don't like it out front. I don't have an air box and a lot of the items most guys have under the seat are not there on mine. The side covers essentially scoop air and it will run through the cooler. I have also found 2 aluminum 12V fans that will most likely go on the back. I have not decided whether they will be thermally actuated or not.
As always, that's for the feedback Motorhead.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- PLUMMEN
- Thank you received: 104
but an oil cooler even if it is not getting much air is still adding volume which helps keep the oil cooler and is also going to remove as much heat as the air flow will allow.
which is more cooling than you will get without one. :whistle:
thats my .02 fwiw,
- kaw-a-holic
531blackbanshee wrote: more air is always better.
thats my .02 fwiw,
That's they way I viewed it Leon. Pretty much a stock motor and it always ran fine without a cooler. Moved to AZ so I thought the cooler would be a good idea.
Jon
1977 KZ1000a1
Mesa, AZ
- Forrest
- The Mad Duck
- Thank you received: 180
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- goodfastncheap
- Thank you received: 38
1979 KZ650 B3
KZ Relay Rider #54, Iowa, Nebraska and Kansas
