My GPz750 Resto-mod (pic heavy)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: My GPz750 Resto-mod (pic heavy)
21 Nov 2013 06:18
#613616
i'm with puffin.
the shock is not symmetrical so there for your mount isn't going to be symmetrical.
the shock decided for you :lol: !
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
17 Dec 2013 10:09 - 17 Dec 2013 10:09
#615726
I really haven't felt like dealing with notching the rest of the tubes at compound angles so I've been gathering and fitting parts over the last few weeks.
I got a '98 Vfr800 front rim, a set of Zrx1100 forks and a set of Zx11 triples with handlebars to start.
First thing was to buy some 25mm ID bearings for the Vfr rim to go from the 20mm stock axle to the 25mm Zx11 axle. But then I realized that the 20mm ID inner tube bearing spacer would be impossible to use so I took a chance and ordered a used Zx7 spacer hoping that it would be too long and I could trim it to size. It was so that was easy enough to shorten in the lathe.
Then I found out the Vfr inner hub has some extra casting material that needed to be filed down to let the bigger OD of the spacer tube pass through.
So with the correct bearings, everything played well together until I had to figure out the wheel spacers. Because the Zx/Zrx11 uses a mechanical speedo drive the left axle clamp is offset to get the needed room. This meant that I could not simply make two identical spacers. But here's what I came up with...the left spacer being about 4mm longer than the right.
Everything together and ready for me to figure out brake fitment and spacing
Which lead me to my next headache: finding a set of 310mm rotors that have the correct offset and bolt pattern for a Vfr800 rim in a set of Zrx1100 forks held in place by Zx11 triple clamps. I've looked and they don't exist. So I did a lot of research and found that I could possible use a set of Cbr600RR rotors or certain models of Gsxr rotors with the right adapter/spacer. I found a set of used aftermarket Cbr600RR rotors for a good price and bought them just so I'd have a starting point.
I also bought some 5" OD x 1.00" thick 6061 round bar stock from eBay.
All was right with the world as I had drawn up some sketches of the spacer/adapter until I placed the rotor on the wheel to see what actual offset I needed.
It turns out that I failed to take into account a small lip to hold the rotor concentric to the space. So now I'm pretty sure that the fastener that will hold the spacer to the rim will also try to take up the same space as the concentric lip. And that's where it's been sitting for the last week or so.
Any thoughts besides buying more aluminum and different rotors?
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 17 Dec 2013 10:09 by StreetfighterKz.
  • 531blackbanshee
  • Vendor
  • Vendor
17 Dec 2013 12:38 - 17 Dec 2013 12:42
#615736
maybe i'm missing something :whistle: .
but it looks to me like you could countersink the bolts the hold the adapter to the wheel and then machine your locating lip around.
the countersinks will interrupt with the lip but you will still have enough lip to locate the rotors.
what am i missing?
Last edit: 17 Dec 2013 12:42 by 531blackbanshee.
  • StreetfighterKz
17 Dec 2013 15:07
#615744
531blackbanshee wrote: but it looks to me like you could countersink the bolts the hold the adapter to the wheel and then machine your locating lip around.
Hmmm.. It hadn't crossed my mind to drill the holes first. I just assumed that machining the offset/lip and everything else would be first. I'll have to take another look at my process.
Thanks Leon! ;)
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • Puffin
  • Puffin's Avatar
19 Dec 2013 14:29
#615935
hows the Brainstorming going Doug have you a solution ?
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • StreetfighterKz
19 Dec 2013 14:47
#615936
Not a solid one yet. I wouldn't have an issue if I had a vertical mill but I don't so I may go with Leon's advice, I'm gonna try to get out to the garage this weekend as it'll be in the upper 40's compared to the mid-20's/low 30's recently.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
19 Dec 2013 21:14
#615956
Good stuff, man. Drive on.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • StreetfighterKz
20 Dec 2013 20:18
#616055
I forged ahead today on the brake rotor adapters/spacers. Let me just say that working with 5" OD stock on a 7" swing lathe takes some out of the box thinking but I think I got most of the problems solved except the spacer-to-rim mounting bolts being so close to the lip. Using socket headed bolts and thinning the lip a small amount will hopefully completely solve the issue.
First I drilled a hole in the center and used an expanding arbor to hold the workpiece so I could form the lip that keeps the rotor concentric. Once that was done I drilled and tapped two holes and used those to mount the piece to a faceplate where I could bore the ID to fit over the rim's hub.
Then with some careful positioning I used a transfer punch to mark two of the holes for the spacer-to-rim bolts.
I still need to finalize the thickness, drill the other 8 holes, plus clean it up a little to reduce some weight, but here it is in a temporary state.
At least I made progress, as I've been brainstorming about this for a week or so now.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
21 Dec 2013 11:42
#616075
I finalized one side today. I was able thin the lip and get enough clearance to use socket headed screws just fine. The spacer/adapter actually ended up thinner than I thought but still plenty of material for strength.
How it looks all bolted up.
Just about as centered as I think I can get it.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Bad Kaw
  • tk11b40
  • tk11b40's Avatar
21 Dec 2013 21:27
#616098
Nice work !!
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • StreetfighterKz
29 Dec 2013 15:22
#616650
Since the holiday is done and life is back to normal, I made my way back to the garage and made the third version of the right lower shock mount tube.
But I'm not sure if I want to keep a similar design for the upper tubes or go parallel with them..
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
31 Dec 2013 16:11
#616895
Soooo........the Vfr800 rim I bought turns out to be a 16" Cbr900RR front rim. I didn't notice it until I went to mount the 17" mock-up tire I have and the tire practically fell over the 16" rim. So now I'm back to looking for a 17" Vfr rim plus trying to resell the 900RR rim since it's been more than 2 weeks and the seller won't take a return.
I'm hoping that when I do get a proper 17" rim my axle spacers and brake adapters will still work but I doubt it.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
