My GPz750 Resto-mod (pic heavy)
- StreetfighterKz
Re: Re:My GPz750 Resto-mod (pic heavy)
13 Sep 2016 10:18
I did some heavy lifting (literally) the last couple weeks. The turbo engine is just different enough from the NA engine that I swapped them out so I could be sure everything fit 100%. This allowed me to find the correct offset front sprocket (the turbo has a 6mm longer output shaft) plus finalize my exhaust system.
While I had the engine out I went ahead an dressed up where I removed the lower front cross-member.
Once the turbo lump was in place, I moved on to the exhaust. (Don't mind the weld quality, as I'm using flux-core wire.) I thought it turned out nice and followed the lines of the frame and body work well.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Re: My GPz750 Resto-mod (pic heavy)
14 Sep 2016 05:42
the exhaust lines follow everything pretty well i think :evil:
- Bendix94
20 Jun 2022 16:28
Hello Doug, Where did you get this thin red tail light for the GPZ750? Best regards Peter Bendix Søndergaard
