80 kz750 ltd rescue ..bobber project
- baruch77
Re: 80 kz750 ltd rescue ..bobber project
09 Jun 2013 11:44
Hi! Well the project its almost done ... i need plug the :woohoo: wire harness, purge the brakes. Attach the carbs..... so, almost :woohoo: . Actually i need some help with the drive chain, i know the OEM its 630 but not sure how many links, i extend the swing arm 4" so i need a long one.... one more thing HELP!! me with the jets size.... cabs have 52mm pods filtes and open pipes no baffles, if some one can give me an idea about the rejected sizes im really appreciate. Thanks
Attachment IMG_20130607_124637.jpg not found
Attachment IMG_20130607_124717.jpg not found
80 kawa 750ltd h1 bobber project.
- baruch77
20 Jun 2013 02:06
Hi people ... well some advance on the project, im waiting for dynojet stage#3 and drive chain.
Attachment IMG_20130614_131843.jpg not found
Attachment IMG_20130614_131950.jpg not found
Attachment IMG_20130614_132017.jpg not found
Attachment IMG_20130614_132026.jpg not found
- QNman
- djturnz
20 Jun 2013 22:49
Are you doing a530 conversion?
1982 KZ750 (4) LTD
- P21
20 Jun 2013 23:10
gas tank looks like sportster
put a coffin tank on that bad boy no offence but get rid of the harley part!
Kawasaki KZ 1000 Police (2002) P21
- P21
20 Jun 2013 23:15
as to your sprocket the teeth look worn bad :dry:
Attachment sprocket_2013-06-20.jpg not found
- P21
20 Jun 2013 23:18
i like where your going with this project
- djturnz
21 Jun 2013 05:30P21 wrote: as to your sprocket the teeth look worn bad
Z1enterprises helped me with my 530 chain conversion. Saves a bunch of actual weight as well as rotational weight.
1982 KZ750 (4) LTD
- QNman
21 Jun 2013 20:39P21 wrote: gas tank looks like sportster
It looks like a peanut tank - lots of choppers have used them over time. Looks like it fits nice, but high - which I like.
The following user(s) said Thank You: baruch77
- baruch77
28 Jun 2013 23:32Attachment IMG_20130614_131843_2013-06-28.jpg not found
- Kisa
29 Jan 2017 07:56
Your bike came along beautifully. I have a question. The air fliter system you went to, what if any are the draw backs to using the 4 independent and removing the air box/ cylinder air filter?
