80 kz750 ltd rescue ..bobber project
- baruch77
Re: 80 kz750 ltd rescue ..bobber project
28 Apr 2013 17:48 - 28 Apr 2013 17:52
Well some pics from the swingarm extended 4" and the chopped frame.
Attachment IMG_20130425_124446.jpg not found
Attachment IMG_20130425_124530.jpg not found
Attachment IMG_20130425_124607.jpg not found
Attachment IMG_20130425_124747.jpg not found
80 kawa 750ltd h1 bobber project.
Last edit: 28 Apr 2013 17:52 by baruch77.
- baruch77
28 Apr 2013 17:57
Motor clean painted and covers polished done.
Attachment IMG_20130425_121226.jpg not found
Attachment IMG_20130425_121726.jpg not found
Attachment IMG_20130425_122521.jpg not found
Attachment IMG_20130425_122536.jpg not found
- geohaydook1
29 Apr 2013 12:04
How did you get the shiny bits on the engine so shiny? What kind of polish etc.did you use?
1980 KZ750e
1981 KZ650 csr (fate undecided)
- baruch77
29 Apr 2013 13:08
I get a polishing set by menards it have a 5 different kind of compounds and 3 pads you can use it whit a drill ..actually you can see the package in the fist pictures. Thanks and good luck.
- baruch77
09 May 2013 11:15 - 09 May 2013 11:21
Hardtail almost done..!!
Attachment IMG_20130507_130617.jpg not found
Attachment IMG_20130507_130644.jpg not found
Last edit: 09 May 2013 11:21 by baruch77.
- Jrbrownie00
09 May 2013 11:53
looks really good. how are you going to mount the seat?
82' kz750 ltd.
The following user(s) said Thank You: baruch77
- Jrbrownie00
09 May 2013 11:53
82' kz750 ltd.
- baruch77
09 May 2013 12:11
Hi jrbrownie00 well im going to weld an other piece of pipe on the from to put the hinge , and im going to use a solo seat whit 5" tall springs on the back.
- djturnz
- baruch77
15 May 2013 10:44
HI EVERYONE!! WELL NOW THE PROJECT STAR TO TAKEN FORM.
Attachment IMG_20130514_132126.jpg not found
Attachment IMG_20130514_120222.jpg not found
Attachment IMG_20130514_132014.jpg not found
Attachment IMG_20130514_132022.jpg not found
Attachment IMG_20130514_132055.jpg not found
- Jrbrownie00
15 May 2013 11:23
sick! I like the repurposed front fender, clever.
82' kz750 ltd.
- baruch77
09 Jun 2013 11:38
Hi! Well the project its almost done ... i need plug the :woohoo: wire harness, purge the brakes. Attach the carbs..... so, almost :woohoo: . Actually i need some help with the drive chain, i know the OEM its 630 but not sure how many links, i extend the swing arm 4" so i need a long one.... one more thing HELP!! me with the jets size.... cabs have 52mm pods filtes and open pipes no baffles, if some one can give me an idea about the rejected sizes im really appreciate. Thanks
