Budget Build '78 KZ1000
  • holleman14
  • holleman14's Avatar Topic Author
Re: Budget Build '78 KZ1000
02 Dec 2012 20:29
#561010
Hi Doug
Once I have the new brace welded, I will cut the old brace off. This should minimize any warpage during the process. This will also give me room for some shock mounts on top of the arm. (It would be kind of a wild look with both braces thou......... B) )
Cheers Shannon
2003 VFR800 ABS
1975 CB400f
1974 Z50
1978 KZ1000 Retromod
1983 Goldthing (next project, cafe)
1978 CX500 (Cafe project)
2010 VFR1200f
1998 VTR1000
  • wireman
  • wireman's Avatar
02 Dec 2012 22:08
#561027
Id say that swingarm would be plenty strong without either brace B)
  • holleman14
27 Dec 2012 22:56
#564908
Hi all, been away for a while but still making some progress on the KZ. here are some pics of what I've been doing.
Got the USD's moded/installed
Attachment frontendusd.jpg not found
Mocked up the rear sets. thinking about changing the location of the rear master cylinder.(relocate it closer to pedal)
Attachment rearsetbrake.jpg not found
Attachment rearsetshift.jpg not found
And a gauge mount.
Attachment gb4.jpg not found
Attachment gb3.jpg not found
Attachment gb2.jpg not found
Attachment gaugebracket.jpg not found
Let me know what you think. I'm open to any thought or ideas.
Shannon
2003 VFR800 ABS
1975 CB400f
1974 Z50
2010 VFR1200f
1998 VTR1000
  • wireman
  • wireman's Avatar
27 Dec 2012 23:41
#564917
Looks good to me B)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Dec 2012 00:14
#564932
i am diggin all the fab work :evil: !
lookin good so far,keep us posted.
  • holleman14
21 Jan 2013 22:35
#568568
Ok, haven't been doing to much KZ lately. Repaired the stator wires and messing with the handle bar arragement. What do you think, clip on's with custom mounts or fat bars? (KX high bend)
Clip on
Attachment kzclipon.jpg not found
Attachment kzclipon2.jpg not found
Fat Bar
Attachment kzphatbar.jpg not found
Attachment kzphatbar2.jpg not found
2003 VFR800 ABS
1975 CB400f
1974 Z50
2010 VFR1200f
1998 VTR1000
  • kzz1king
  • kzz1king's Avatar
21 Jan 2013 22:52
#568569
Can't help you with the bar decision, looking at clipons or superbike bars myself. What are your resets off of or are they for a KZ?
Wayne
Home built KZ1000 turbo setup
  • holleman14
21 Jan 2013 23:03
#568571
Hi Wayne'
Resets are '95 gsxr 750(the wings are cut off). I have only 1 bolt in the top mounting hole just to hold them in place. I am going to weld a lower bolt hole mounting point to the frame.
Shannon
2003 VFR800 ABS
1975 CB400f
1974 Z50
2010 VFR1200f
1998 VTR1000
The following user(s) said Thank You: wireman, kzz1king
  • 531blackbanshee
  • Vendor
  • Vendor
22 Jan 2013 01:27
#568597
my vote goes for the dirt bike bars.
  • bluezbike
  • bluezbike's Avatar
22 Jan 2013 03:55
#568616
It very much depends on what you will be doing with the rest of the bike....my personal preference is for the fat bars. I can see the clip-ons arrangement looking good with a pair of larger headlights though. Like it so far a lot!!
79 KZ 1000 LTD
  • mick z1a
  • mick z1a's Avatar
22 Jan 2013 05:07
#568619
how are you going to use the bike, daily rider, rough roads, distance? personally ive never like the riding style of drop bars, i prefer to sit on the bike than lay on it. what sort of budget, big budget ? :woohoo:
  • holleman14
13 Feb 2013 23:07 - 17 Feb 2013 09:57
#572289
So decision made, fat bars it is. I'm in to over 40 crowd and some things are not like they use to be. Even my VFR I feel a little to far forward. Just haven't been able to swallow the pill for a set of helie bars.
So a bit of progress on the bike. The rear sets are done, some frame bracing done (more to do) and decided to change the rear brake linkage set up. It is a bit different, some of it will be hidden when I brace the frame in this area. It also will clean up frame in this area leaveing a chance to mount some rear pegs.
Attachment kzbrakelinkage.jpg not found
2003 VFR800 ABS
1975 CB400f
1974 Z50
2010 VFR1200f
1998 VTR1000
Last edit: 17 Feb 2013 09:57 by holleman14.
