HollywoodMX's Drouin Supercharged 77 KZ1000!!
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
07 Nov 2012 11:14
a custom fabbed aluminum belt cover with holes and lexan over each pulley would be cool.
- zed1015
07 Nov 2012 16:04Sweet. How did you know how to delete the relays? When I did this one the TR-1 I used the wiring diagram with a forum post of instructions, more or less.
You only need a relay if you are switching a current that is more than the switch gear can handle
e.g starter motor, twin headlights etc.
As for the choice of wheels discussion the widest a std Zed frame will take whilst keeping the wheel true central is a 5.5 inch rim e.g, zx636,Z750,zx7r,zx9 etc .
With a 5/8 offset sprocket the measurement from swingarm spindle center (chassis/wheel center line) to the inside face of the sprocket is 101mm which usually equates to approx 8mm off the rear wheels sprocket carrier to align the chain.
A zx10r rear is 6 inch and won't fit unless it's offset which i think is bad practice.
If you want better/quicker handling rather than pose value go for a 170 rear tyre.
The ideal set up is 5/8 offset front with 19teeth, 530 pitch to get max clearance between the chain,frame and swingarm.
The original zeds final gearing is 2.2 to 1.
To compensate for the smaller 17" rim use 1.92 to 1 for the closest equivalent.
The following user(s) said Thank You: bluezbike
- wireman
07 Nov 2012 16:11Thats exactly what it isStreetfighterKz wrote:Zedone wrote: Can you post more pics of your swingarm? I've never seen a Calfab with that type of extruded alum. tubing before... maybe it's a one off?
The swingarm on the supercharged bike just looks like a stock arm with an extra tube brace welded underneath and then painted silver.
Later, Doug
- Drooz
07 Nov 2012 16:46 - 07 Nov 2012 16:48Hollywoodmx wrote:Drooz wrote: Hey, nice Project!!I'll be following along with interest!
I believe the zx6r rear wheel is 1/2" narrower than the zx10r. At least, the '04 -'05 one's are. It made it a little easier to get the chain inside the frame and past the wheel/tire. You can still use a 180mm tire.
We used a zx6r rear wheel and a whole zx10r front end on my KZ.
Ok good to know. Do you have pics of your bike in thread somewhere?
Sure, I've got a few pics.
There are a few others if you need some detail, but that's pretty well it. I also run a 5/8" offset sprocket (see pic) and an idler wheel to keep the chain off the swingarm bottom brace. There is a mylar strip on the top of the swingarm (see pic), and it's needed!!
Hope that helps some.
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
Last edit: 07 Nov 2012 16:48 by Drooz.
- Hollywoodmx
08 Nov 2012 00:18 - 08 Nov 2012 00:27Zedone wrote: Nice bike Hollywood!
Very innovative head work.
You might want to install some SS braided brake lines, and it appears that your rear rotor has a decent size groove worn into it... I'm wondering how your brake pads are also. The stock Z1 KZ brakes are OK at best... let alone having a blower thrown into the equation :laugh: . A set of super bike bars or clip-ons would really inspire confidence also.
Someone spent alot of time and resources into your bike... I like the direction your headed with a super bike / cafe influence.
It almost looks like your pipe has been ceramic coated (hard to tell from a pic though). The new oil coolers available are much larger and make a noticeable improvement over the older ones.
Regards, Doug
Ya he did, he spent lots of money on the bike. Back in 84 I think, he said the supercharger with all the "required" pieces cost him $3500! Pretty crazy. Engine parts were in the thousands. Judging by his receipts be blew the motor in the 90s once, there was another list of engine parts from the 80s I didn't list, thus why its 1045 now.PS. Anyone know what the snowflake does?? Yup it is ceramic coated there is a receipt for it. I will be painting it black. Sure I will add pics.
Later, Doug
It was powder coated silver. I think he may have sent it to Calfab to re-enfornce as there is calfab docs in the folder.
531blackbanshee wrote: a custom fabbed aluminum belt cover with holes and lexan over each pulley would be cool.
Ya I think so too. My buddy is going to cut the opening with a cnc.
zed1015 wrote:Sweet. How did you know how to delete the relays? When I did this one the TR-1 I used the wiring diagram with a forum post of instructions, more or less.
On the Yamaha 2 out of 4 realys were for safety things that I deleted, thats why I was asking.
Hey that's really helpful info on the wheels and the final drive. I would prefer the 5.5 anyways.
But I did fall in love with these wheels but I would get them powdered gold; Aprilia RSV wheels. I was able to find a complete set of forks, breaks, trips, etc. But I'm not sure if that's venturing into no mans land of endless fab work..
Drooz wrote:Hollywoodmx wrote:Drooz wrote: Hey, nice Project!!I'll be following along with interest!
Sweet ride man. I like the shocks, I mean $HOCK$..hehe. What swing arm is that, gsxr?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 08 Nov 2012 00:27 by Hollywoodmx.
- zed1015
08 Nov 2012 05:26
The snowflake is the lock-up clutch mechanism that is bolted to the clutch pressure plate.
- Drooz
09 Nov 2012 19:36Hollywoodmx wrote:Zedone wrote: What swing arm is that, gsxr?
JMC, England.
Nice swing arm.Difficult folks to deal with. :blink:
- Hollywoodmx
21 Nov 2012 01:54 - 21 Nov 2012 01:54Patton wrote: Scroll down to
CENTRIFUGAL LOCK UP CLUTCH
Click > kzzone.com/clutches.html
That makes sense now, thanks.
Update: Beneli body parts are in transit, Ive still figuring out the the wheels forks swingarm brakes stuff. I have been on ebay trying to get all the parts from one bike type to keep it simple but having difficulty in making sure I get a good deal while still in getting them all at the same time. Currently looking at zx6, zx10,zx14 as the 6 spoke wheels to me are the most attractive.
An issue is I'm not a fan of the squid swing arms (zx's) and favour the gsxr and busa look though as it resemble more stock like.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 21 Nov 2012 01:54 by Hollywoodmx.
- Kitten Tooth
21 Nov 2012 02:06
Wheres the "Quagmire has discovered internet porn" picture? This thread truly deserves it. Your one lucky person. Does it run on Alcohol or just straight gasoline? Im curious
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- lushbaugh
- everybodys a pro......
21 Nov 2012 02:32
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
21 Nov 2012 11:12
sounds like you need one of them modified busa arms like rslingshot done the how to write up on removing the upper brace and adding a lower brace :evil: .
