Yoshimura R&D Superbike
  • Mark Wing
  • Mark Wing's Avatar
Re: Yoshimura R&D Superbike
13 Sep 2012 19:07
#548512
No Mark my pressure cast pistons are three ring pistons.
Mark
Yorba Linda Cal.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
13 Sep 2012 20:00
#548518
OldSchoolZ wrote: In regards to high rpm. I rode a Z1R years ago that was lightly bored and mostly stock minus valve spring, retainers ad valves. It had huge cams in it. Even the valve cover was grinded for clearance, shim under buscket.
The power came on at 9K and would light up the tire from 9k-13k. It was insane. :woohoo:
3rd gear when power came on simply lit the rear tire up and pulled like a freight train.
How long that motor would last, might be a different story though. :laugh:
I can more specifics on that motor is anyone wants them.
I'm stiil in touch with Jay in Houston. He owns JB Cycles and does a lot of turbo work and insane modding.
His goof around bike is an 86 GSXR1100 fuel injected. :cheer:
I wouldnt run my bike at 13k. That poor bike. I keep my limiter set round 9,700, Just because i want to be a little lower than what i consider max rpms for me.
1977 KZ 1000 work in progress
  • turboguzzi
  • turboguzzi's Avatar
14 Sep 2012 05:55
#548594
mtb, that piston you posted looks already a much better proposition
and guys, just like with speedos, dont believe everything that your tacho shows :ohmy:
show me dyno curves with RPM's numbers on the bottom :)
I'll be happy to see the dyno chart of a fast road/track (not drag) 900-1000 motor that peaks after 10K
Larry, have you ever seen one? :)
BTW, my worry wouldnt be pistons coming apart, but running two rings / very high domes.
My 750/810, being a big bore is bound to peak at lower rpm than a 716. do you have a dyno chart showing peak hp @ 10.5 or is it feel of the pants?. its got andrews #35 cams BTW.
I am pretty sure that there are plenty of huge valved drag motors that can peak higher for 10 seconds, but not quite relevant for MTB's fast road track intentions.
  • Powerstroke_fan
14 Sep 2012 08:41
#548606
I am sure people do run there bikes and make power above 10k. But If your that worried about revving that high and possibly doing damage a expensive built motor, wouldnt be smarter to buy diffrent cams to move the powerband down some? So the motor isnt tached so high, Talking street riding, not dragracing at the strip.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 Sep 2012 13:33
#548637
if u dont plan on racing, then a bigger bore is in order. it will help u take advantage of newer flatslides, that r only available in larger bore sizes. keep the compresion at 10.25:1 and it will be much more user freindly. pump gas is easy to find, and u will need a refill every hour and a half(100 miles).
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
14 Sep 2012 15:19
#548649
I really appreciate all of the feedback, but I don't want to go the big-bore/low-end torque/stump-pulling cams route; that's not "true" to the bike. If I were making a street bike, I'd most certainly be going that route, but that's now what I have in mind for this build. This is NOT a regularly driven street bike.
I'm also not worried about damaging anything at high RPMs because I will have built the engine to run at high RPMs. If I'm willing to spend two grand on crank work (emphasis on WORK, I don't even get a new crank out of the deal) and rods, don't you think I will have put an appropriate amount of time into properly researching my valvetrain, modifying oil passages/pump, and setting up piston/valve clearance? Additionally, I'd be running an electronic tach, not a mechanical tach; with a Dyna2000, which has a limiter on it.
The Yosh pistons I have are 10.8:1 compression, so it's fine to run premium spiked with additives, especially considering it's not going to be frequently used.
I also completely understand the warnings regarding the 2 piston rings, but why is a high piston dome an issue? Other than valve clearance and compression of course.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • mtbspeedfreak
14 Sep 2012 15:20
#548650
If you don't mind me asking Mark, how many times a month are you out on your KZ [it's an 1197, no?]? What compression are you running? Do you have 93 octane up there, or just 91?
How many other of you have bikes with extensive engine work that you ride? How frequently do you ride? I have a stock 903 that I ride everyday, when/if I do any engine work to it, it will be minimal as I don't want to lose ANY streetability.
2000 ZRX 1100
  • mtbspeedfreak
14 Sep 2012 15:27
#548651
turboguzzi wrote: and guys, just like with speedos, dont believe everything that your tacho shows :ohmy:
That reminded me, I've been meaning to hook up my cable to an electric drill and get creative with photoshop.
2000 ZRX 1100
  • mtbspeedfreak
14 Sep 2012 18:45 - 14 Sep 2012 18:48
#548682
I'm headed out of town this weekend, but I wanted to get this article uploaded so you can check it out. Hope you enjoy!
[img
MMS_0920 by mmsmithgall , on Flickr
[img
MMS_0921 by mmsmithgall , on Flickr
[img
MMS_0922 by mmsmithgall , on Flickr
[img
MMS_0923 by mmsmithgall , on Flickr
2000 ZRX 1100
Last edit: 14 Sep 2012 18:48 by mtbspeedfreak.
  • turboguzzi
17 Sep 2012 04:50
#549188
"but why is a high piston dome an issue? "
Pretty old school, no detonation preventing squish band.
If i was you, i'd rather take "Cycle" mag's story on Muzzy's work on the 1000 (and 750 too) as a reference..... with all due respect to Art Friedman, he was never too technical, Kevin Cameron was way better in explaining Muzzy's tunning approach in detail.
info might not be exactly period for the bike by a 2-3 years but muzzy deployed much more advanced tuning techniques to the kawi fours.
  • mtbspeedfreak
17 Sep 2012 13:34
#549246
turboguzzi wrote: If i was you, i'd rather take "Cycle" mag's story on Muzzy's work on the 1000 (and 750 too) as a reference..... with all due respect to Art Friedman, he was never too technical, Kevin Cameron was way better in explaining Muzzy's tunning approach in detail.
I did a quick search but was unable to find that article, any chance you have it or could give a little bit more information so I can hopefully look it up?
Thanks!
2000 ZRX 1100
  • wireman
  • wireman's Avatar
17 Sep 2012 13:38
#549249
turboguzzi wrote: "but why is a high piston dome an issue? "
Flatter piston dome promotes better flame travel/easier combustion B)
