Finished - for now !
- Motor Head
Re: Finished - for now !
15 Jul 2012 21:33 - 15 Jul 2012 21:42
Sounds like it just needs a bit more fiddling around to get it set. If they are all responding to adjustment, it just takes some time to get it. Keep a fan moving air across the motor when messing around to keep the temp down, a good sized one.
Oh have you re-torqued the engine after the first couple of heat cycles? Make sure you do if you haven't yet, cold of course.
Last edit: 15 Jul 2012 21:42 by Motor Head.
16 Jul 2012 17:36
your bike really turned out nice,good job.
- faffi
16 Jul 2012 18:25
Great transformation
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- KZ1000inaus
- Luminous Red KZ1000 A2
19 Jul 2012 01:08i removed the carbs and did an on bench set up with the .7mm wire. they were all out by quite a lot. It's amazing how much better it runs. I've also tweaked the pilot screws as it was running rich (the only way i could keep it running before manual carb setup) so hopefully that's it for nowMotor Head wrote: Sounds like it just needs a bit more fiddling around to get it set. If they are all responding to adjustment, it just takes some time to get it. Keep a fan moving air across the motor when messing around to keep the temp down, a good sized one.
Oh yea i did re-torque the head nuts
- Motor Head
19 Jul 2012 01:15
Did you have a look at the simple vacuum sync tool I posted the link to? That little tool is really sensitive to adjustments, and real cheap.
- KZ1000inaus
19 Jul 2012 02:26I'd already bought a set of vacuum gauges but the carbs were so out it was impossible to set up using the gauges.Motor Head wrote: Did you have a look at the simple vacuum sync tool I posted the link to? That little tool is really sensitive to adjustments, and real cheap.
i'll run it for a bit and then tweak with gauges
- gwolever
19 Jul 2012 16:07
Looks great! Paint was worth the money. Flawless.
1982 KZ1000 CSR
