Finished - for now !
  • KZ1000inaus
  • KZ1000inaus's Avatar Topic Author
  • Luminous Red KZ1000 A2
15 Jul 2012 07:06
#536014
Well the old girl is back together and painted as close as i could guess to Luminous red, and even if it's not accurate I'm happy with it. :-)
A before pic (black) is attached which is what the bike looked like when it was imported from the US. That LTD seat seemed to shrink the bike !
Spent about $4k AUD so far ($900 on paint), and I'm nearly there. But knowing me I probably wont be able to stop until it's close to new looking.
Attachment Image1.jpg not found
Attachment DSC_0001.jpg not found
Attachment DSC_0003.jpg not found
Attachment DSC_0005.jpg not found
Attachment DSC_0017.jpg not found
Attachment DSC_0007.jpg not found
  • wireman
  • wireman's Avatar
Re: Finished - for now !
15 Jul 2012 07:16
#536015
Looks good from where Im sitting! B) B) B) B) B)
  • peter1958
  • peter1958's Avatar
  • dejavoodo41
  • dejavoodo41's Avatar
15 Jul 2012 09:01
#536023
That is sweet looking. Great Job!
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
15 Jul 2012 09:23
#536026
Great looking bike!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • bluej58
  • bluej58's Avatar
15 Jul 2012 09:43
#536031
Wow Craig you didn't waste any time finishing her up, shes a beauty.
Now get out and ride that puppy B)
JD
78 KZ1000 A2A
  • trianglelaguna
  • trianglelaguna's Avatar
15 Jul 2012 11:45
#536055
very cool
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Motor Head
  • Motor Head's Avatar
15 Jul 2012 14:16
#536088
Hows the Motor running now after the Top End job?
Paint looks very nice, sharp looking bike. Watch out for the Coppers! :woohoo:
  • KZ1000inaus
15 Jul 2012 18:55
#536150
Motor Head wrote: Hows the Motor running now after the Top End job?
Cheers all.. :-)
It's still running a little lumpy when cold and then when warmed up lumpy down low and i made it worse by playing around with mixture (and trying to balance carbs) but ran out of time yesterday. I might just give in on this one and book it in for a proper setting up. above 25000RPM she runs really sweet.
  • bluej58
  • bluej58's Avatar
15 Jul 2012 19:19
#536152
A good tuner will set them up right and you should never have to screw with them again.
78 KZ1000 A2A
  • Motor Head
15 Jul 2012 19:20 - 15 Jul 2012 19:27
#536153
Well did you replace the carb holders/ intake boots? Go through the carbs? Check thoroughly for vacuum leaks? Set the Fuel level in the bowls, using the clear tube test for a sight gauge?
Did you pre-set the sync on the bench?
Engine Compression even now? At what pressure?
A cheap home made pressure differential vacuum sync tool can be made real cheap, like $6 here in the USA. Probably about the same down under. Bunnings would have the stuff, I'm pretty sure.
www.kzrider.com/filebase/doc_download/215-simplevacsynctool
Last edit: 15 Jul 2012 19:27 by Motor Head.
  • KZ1000inaus
15 Jul 2012 21:19
#536188
Motor Head wrote: Well did you replace the carb holders/ intake boots? Go through the carbs? Check thoroughly for vacuum leaks? Set the Fuel level in the bowls, using the clear tube test for a sight gauge?
yea replaced carb holders (in and outs) removed and cleaned carbs (very clean already) and i set the floats with clear tube on bench this weekend.
didnt pre-set the sync on bench though.
Will check compression again tonight, i wanted to run it for a couple of short runs before checking.
i bought a set of vacuum gauges from the UK pretty cheaply and have been using them. i managed to get 1&2 the same and 3&4 but could not get the pairs to match..
