78 Kz650D
- strobel5
78 Kz650D
08 Jul 2012 23:31
So I bought this for a good deal, alot of new parts and was running good. It turned into a project less than 24 hours after owning it. Blew a piston, so I began the journey of rebuilding the engine and doing some other stuff while i'm at it. Keep in mind this is my first time getting this involved with a motorcycle.
Here she is how I got her.
The old bars have to go.
New bars, lowered headlight, and new turn signals
There is the crap piston
Another look
This is through out the engine
Attachment kz650.jpeg not found
Attachment IMG_1100.JPG not found
Attachment IMG_1106.JPG not found
Attachment IMG_1115_2012-07-08.JPG not found
Another look
Attachment IMG_1116.JPG not found
Attachment IMG_1120_2012-07-08.JPG not found
1978 kz650d(SR)
- strobel5
Re: 78 Kz650D
08 Jul 2012 23:34
Got it tore down some more
Slug and metal in the oil pan, not looking good.
Engine out and metal everywhere.
New garage, how she sits.
Attachment IMG_1123.JPG not found
Attachment IMG_1135_2012-07-08.JPG not found
Attachment IMG_1139_2012-07-08.JPG not found
Attachment IMG_1140.JPG not found
1978 kz650d(SR)
- strobel5
Re: 78 Kz650D
08 Jul 2012 23:40
Piston
and more piston
Figured I work on the seat while I have the jug and head at the machine shop.
Rusted seat pan needs some grinding and painting.
Got it ground up and painted.
Shaved down the old goofy seat, trying to get a 2 up cafe seat.
Going to have my mother do the upholstery. Waiting around to get the parts back.
Attachment IMG_1144.JPG not found
and more piston
Attachment IMG_1146_2012-07-08.JPG not found
Attachment IMG_1147.JPG not found
Attachment IMG_1155.JPG not found
Attachment IMG_1157.JPG not found
1978 kz650d(SR)
- faffi
Re: 78 Kz650D
09 Jul 2012 05:13
You have your work cut out
I would suggest finding a second-hand engine instead of repairing the damaged one, as debris so easily can have clogged a small oil orifice. Also, complete engines likely cost less than new parts needed to repair what you have.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- strobel5
Re: 78 Kz650D
09 Jul 2012 14:36
yeah I looked around for another engine but couldnt find one, there was a parts bike but the guy wanted $600 for it. Right now with the cylinders honed and cleaned and new pistons im in about $85 bucks, plus whatever the head will cost. I am going to flush out the bottom end as much as I can.
1978 kz650d(SR)
- faffi
Re: 78 Kz650D
09 Jul 2012 18:03
Hope it turns out all right for you!
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- strobel5
Re: 78 Kz650D
09 Jul 2012 23:29
Thanks! im sure ill have plenty of more questions to come.
1978 kz650d(SR)
- Motor Head
Re: 78 Kz650D
09 Jul 2012 23:36
Be on the look out for the Cause of the damage. Wrong heat range plug (HOT), or to lean on jetting, possible vacuum leak/ lean, Stuck ignition advancer (not returning), or plugged fuel screen above float valve, plugged jets, etc.
- strobel5
Re: 78 Kz650D
10 Jul 2012 01:14
I think its down to three possibilities: 1. The petcock was leaky and when I drained the oil there was alot of gas in it, so I was thinking the gas diluted the oil and made the engine overheat. 2. The number 4 carb could be running lean. 3. the timing was possibly off but I didnt look to see when I was dismantling the engine. Ill have to check the plugs and I will have to just take the carbs apart and clean them and check them. Whats the best way to clean them without taking them all the way apart and taking all the gaskets and stuff out?
1978 kz650d(SR)
- strobel5
Re: 78 Kz650D
19 Jul 2012 02:14
Still waiting on head to be looked at. In the mean time started working on getting the crankcase cleaned for paint.
Anyone know a good way to get into these fins to clean
I also got a new set of pistons in, only $30
Let them soak in kerosene and then polished the tops
Attachment IMG_1172.JPG not found
Attachment IMG_1173.JPG not found
Attachment IMG_1179.JPG not found
Attachment IMG_1182.JPG not found
1978 kz650d(SR)
- strobel5
Re: 78 Kz650D
19 Jul 2012 02:17
Also anyone know what brand exhaust this is, part of a 4-1 system. Previous owner said that he got it online and had it painted.
Attachment IMG_1174.JPG not found
Attachment IMG_1177.JPG not found
Attachment IMG_1178.JPG not found
1978 kz650d(SR)
- faffi
Re: 78 Kz650D
19 Jul 2012 03:40
I wouldn't recommend painting the engine as it will look sad when stones thrown up by the front wheel starts chipping away at the very paint you put on to make it look nice. But it's up to you, of course.
You probably need a blaster to clean those ribs, either soda blaster or nutshell blaster. Sand will of course work fine, but will change the surface structure, something you won't do unless you are going to paint it.
Cannot help with the pipe, unfortunately.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
