81 KZ750H Project
- uneasy_rider
Re: 81 KZ750H Project
19 Jul 2012 11:07 - 19 Jul 2012 11:13Attachment TankMount1.jpg not found
Attachment TankMount4.jpg not found
I had to widen the front mounts since the ZRX tank was wider so I used a 7/16 tap on the original post (perfect fit), threaded (2) 7/16 standoff, cut 2 pieces of 1" flat bar and welded a new mount for the rubber mounts (3/8" bolts) for the front, 1" flat bar for the rear mounts. Pretty straight forward.
Last edit: 19 Jul 2012 11:13 by uneasy_rider.
- uneasy_rider
19 Jul 2012 11:08 - 19 Jul 2012 11:13Attachment TankMount2.jpg not found
Better pic of front setup. I know it looks a little crude, but so do I!
- Tusch
- mike0537
17 Aug 2012 01:25
Any new progress? I've been watching for updates on this one as I own the front and rear end of a 97 gsxr750 for my 1980 kz750e.
1980 KZ750E
- damarble
17 Aug 2012 11:09
I like that tank but I think the rear of it should sit a hair lower.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- uneasy_rider
02 Sep 2012 13:05 - 02 Sep 2012 13:07
"Any new progress? I've been watching for updates on this one as I own the front and rear end of a 97 gsxr750 for my 1980 kz750e."
Nah, KZ unfortunately took a back seat to a boat project. Will get back on it when the weather turns cold.
Last edit: 02 Sep 2012 13:07 by uneasy_rider.
- uneasy_rider
02 Sep 2012 13:06Agreed it would look better lower, but it hits the backbone of the frame at that height.damarble wrote: I like that tank but I think the rear of it should sit a hair lower.
- BlackZ1R
- Kawasaki in my blood
02 Sep 2012 17:58
Pretty cool project. Either tank looks good on that bike, the ZRX tank looks good on there.
Remember any time you change the length of your rear susp. linkage to adjust the ride height, you change the spring rate. Go longer for lower, spring rate falls. Go shorter for higher ride height, spring rate goes up. Just a thought.
This is going to look good when you're done.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- 650mod
06 May 2013 13:45
Very cool build. I love the looks of that tank on there! Any progress now that winter is over?
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
