Restoring Old KZ!
- edhilgendorf
Re: Restoring Old KZ!
31 May 2012 15:16
New development- I want to do a compression(can this thread be moved to projects...?) test, so I pulled off the timing cover and manually turned the motor (after replacing the oil), it seems to turn a couple times, but then hits a spot where it won't move. The spark plugs are out, so it shouldn't be stuck due to compression. Any ideas what to test for or how to tackle this? Thanks!
- MFolks
31 May 2012 15:33
If you don't have a shop manual, I'd stop now until you get one, as you could possbly be trying to bend a valve. The shop manual will walk you through the timing steps needed to sync the cams and valve train.
Manuals(Some of these websites sell used manuals, just ask)
www.repairmanual.com
www.manualsnmore.com
www.midwestmanuals.com/
www.books4cars.com/
www.repairmanualclub.com/motomanuals/
moto-manuals.com/
www.e-classicbike.com/
www.books4cars.com/
moto-manuals.com/
- edhilgendorf
31 May 2012 15:43
I have a manual- somewhere. After contacting a local bike shop, he recommended rotating the engine back and forth slowly with the marvel in it. I tried that, and now it turns freely by hand. I don't think it would be out of time, as the chain is a manual adjuster and has never had problems, also I haven't taken any thing off the motor other than the timing cover. Is there a way to "flush" the motor? I'll track down the repair manual this week, thanks again.
- MFolks
31 May 2012 16:31
About the only way I can think of "Flushing" the engine will be in first changine the oil,getting it to run, so it gets up to operating temperature and then replacing the oil again. Any flushing solvent may thin out the lubrication between moving parts, possible seizing piston rings, or damaging bearings.
31 May 2012 17:11edhilgendorf wrote: ...can this thread be moved to projects...?....
- edhilgendorf
01 Jun 2012 01:20
No eBay APP ID and/or Cert ID defined in Kunena configurationOk, so got the engine to turn over smoothly, so changed the oil and checked the conpression: 120,70,90,the last one wouldn't read at all.
I'm still dead set on getting this thing running, already paid for the new used ignition.
How does this look:
Thanks for all the advice.
How does this look:
- MFolks
01 Jun 2012 01:42
Low to no compression might mean possibly open or (hope not!) burned valve. I'd get a shop manual and read up on checking the valve clearances. On this bike and the 750's, the cams must come out to replace the valve shims, as they are the under bucket type.
- edhilgendorf
01 Jun 2012 01:56
I was considering a stuck or out of adjustment valve, but I remember before I took the bike, 3 years ago it had a valve adjustment done. After that I probably at 5000 miles at most on it. Looking on Ebay, these motors have up to and over 170 psi per cylinder. Seeing as the valve adjustment was done not even 10k miles ago, and the bike is almost 100 low per cylinder, I feel like I should just jump on this deal. (considering its only an hour drive from my house) Is there something obvious I could be missing here? I will pull the valve cover and check clearances tomorrow, thanks again!
- edhilgendorf
16 Jun 2012 14:39
No eBay APP ID and/or Cert ID defined in Kunena configurationSo swapped the motor, and now looking to continue with the electronic ignition install. Which coils should I go with? The ignition I got was stock from a 81 KZ. I found these on Ebay, look to be in nice condition:
Thanks for any input!
16 Jun 2012 18:08
Would suggest checking with Z1 Enterprises for two brand new ignition coils, and a set of Dyna plug wires.edhilgendorf wrote: So swapped the motor, and now looking to continue with the electronic ignition install. Which coils should I go with? The ignition I got was stock from a 81 KZ. I found these on Ebay, look to be in nice condition:
