What direction should I go with my new KZ?
- damarble
Re: What direction should I go with my new KZ?
03 Jul 2012 23:52 - 03 Jul 2012 23:57
Was doing some mocking and measuring and ran into a hiccup. The triple mount spacing on the Ninja 1000 forks is really wide. If I space the triples at KZ width the bottom triple doesn't catch the mount area, if I slide it down enough to engage, the forks stick out a good two inches from the top.
Options appear to be:
A. different forks - additional exspense, other parts I've sourced may no longer fit
B. 2" drop custom lower triple - least work for me, greatest exspense
C. custom longer dropped headstock - possibly cheap, lots of labor, but can add a tad more rake to get wheel out where it should be
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
Last edit: 03 Jul 2012 23:57 by damarble.
- damarble
08 Aug 2012 03:41
Not much happened since the last post, just lots of running out of gas because my petcock only works in the RES position and I don't have an odometer to count miles. PITA.
However, we should be seeing some shiny new bits from Les here soon.
Also debating whether to spring for an Acewell 2853, the Danmoto knockoff of it, or a set of those 2" mini gauges. A guy is selling new3" all-in-one gauges similar to the Acewell for $55 on ebay but kph only. Dunno if I can replace the face or if not can I put up with doing the conversions all the time.
- damarble
16 Aug 2012 02:48 - 16 Aug 2012 02:50
Last edit: 16 Aug 2012 02:50 by damarble.
16 Aug 2012 12:07
a piece of wire with a slight bend that could be stashed somewhere on your bike could make for a good fuel guage /dipstick.
sounds kinda hillbilly but could keep you from running out of gas :whistle: .
hth,
hth,
- Hatchet
- It's better in the wind.
10 Oct 2012 02:53
I gotta say, I just really, really love what you've done with this.
Bikers are a rare breed.
Harley riders are a dime a dozen.
'83 KZ750 LTD K1. "Don't make me get the belt..."
The following user(s) said Thank You: damarble
- damarble
10 Oct 2012 11:23
Thanks Hatchet. It's nothing extreme, pretty easily replicated.
Only update of late is I added a mini speedo for Dime City Cycles. Whohoo. It's getting cold now, I may have another month of riding then I can take it off the road and swap the USD forks.
- Renninger
10 Oct 2012 14:01
i got to say, that is looking good sir. any plans on exhaust?
- Revboyz
11 Oct 2012 13:34
Looks good. Keep up the good work.
Why leave well enough alone!
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
- damarble
23 Oct 2012 13:02
I think I'll retain the stock exhaust. It sounds pretty good and probably flows a bit better after I wacked the ends off.
It's freezing here so I should be tearing into the front end right now but I had to go and get another project to take up my time, putting a new clutch in a diesel F250. It's kind of funny going from tiny lightweight bike parts to huge heavy truck parts.
