Doctorot's '78 KZ1000 build
- DoctoRot
Re: Doctorot's '78 KZ1000 build
18 Oct 2016 13:07
i'm down in San Jose for the school year, so the riding weather is year round!
- DoctoRot
24 Oct 2016 23:25 - 24 Oct 2016 23:35
The front wheel spacer My buddy turned for me left a little to be desired, but at the time this was the only stock we had so not his fault. I remade it to cover the oil seal and make it a bit more sanitary.
I got a start on the brake mounts. I bored all the holes and then used a thread former to cut M10x1.25 threads. It was my first time using a thread former, and man they are trick. produces no chips, so no backing up every quarter turn, longer tool life. better in every way. I'm never going to by a traditional tap again. I also bored the recesses for the caliper and cut them out of the plate. II still need to clean up theoutside and I want to do some pocketing, How much material do you think i can safely remove? I was thinking about having 1/4" think walls and bottom.
Last edit: 24 Oct 2016 23:35 by DoctoRot.
- DoctoRot
24 Oct 2016 23:25Please Log in or Create an account to join the conversation.
25 Oct 2016 05:17
i think leaving everything a 1/4 inch thick will be plenty strong with the structure that the walls and floor create.
imho
imho
- DoctoRot
30 Oct 2016 00:19
Brake mounts are finished. I started planning out to do the pocketing cuts and shit started getting way too complicated so I just eyeballed em, having a CNC here would be awesome. I'm not a fan of tooling marks unless they are super even (like a CNC), so I blasted the pockets and gave everything else the brushed treatment. I noticed one of the forks is weeping fluid so rebuilding those will be up next.
- spdygon
30 Oct 2016 12:24
wow....that is nice. do those calipers use original kz pads?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- DoctoRot
30 Oct 2016 13:56
Thank you. These Grimeca calipers use a different pad. I'm planning on running Ferrodo Platinum pads
30 Oct 2016 14:50
HOT :evil:
- 750 R1
- Ed_in_Miami
31 Oct 2016 06:34
Wow!! Excellent work, beautiful bike!
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
31 Oct 2016 09:26
those caliper brackets came out nice.good job :evil:
- DoctoRot
08 Nov 2016 00:04
Got the paint cut and buffed. I burned through a tiny spot on the tail but it polished out well enough that I'm cool with it, also some flaws in the stripes on close inspection but not bad for first time doing that or the polish.
