1982 kz1100 shaft
  • bearshawk
  • bearshawk's Avatar Topic Author
Re: 1982 kz1100 shaft
17 Oct 2011 18:44
#483827
ok i got my new coil in the mail today, and it read 3.3 ohms and the wires are both intact, i slapped her on and still nothing... the odd thing is... im spraying ether into all the cylinders through the carbs and i took the first spark plug out to check the spark and it hasnt even been discolored at all yet... they are all brand new and this one still looks factory, no soot or carbon at all, soooo am i not even getting my ether/gas into the cylinders?! there IS spark on all 4 plugs
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods :)
1998 honda superhawk 1000-fun in the twisties :)
1982 kz1100 A2 shafty, current project
  • bearshawk
17 Oct 2011 18:45
#483828
also how loud is a kz1100 on startup? i push the button and the engine spins over fine but its LOUD i dont know if its abnormally loud but its definitely louder than my 750 starting up using the electric start
  • Motor Head
  • Motor Head's Avatar
17 Oct 2011 21:23
#483862
So when you tried the Ether it did nothing, no pops backfires, or anything?
Can you make and post a video? If so that may help, listening to it try and turn over and start.
Have you checked compression? I didn't see that in your post.
  • SlowRoad
  • SlowRoad's Avatar
17 Oct 2011 22:37
#483876
My 81 KZ1100 is noisy when starting. Thought it was just mine. Maybe since they both are, it's normal.
1981 KZ1100-A1 Shaft
1997 Valkyrie GL1500
1998 KLR650
1978 KZ750-B Twin
  • bearshawk
18 Oct 2011 01:38
#483894
Motor Head wrote: So when you tried the Ether it did nothing, no pops backfires, or anything?
i havent checked compression but the PO.. TOLD me that it was running right up until the spark failed... soo unfortunately my compression tester is at home 2 hours away
  • bearshawk
18 Oct 2011 01:39
#483895
SlowRoad wrote: My 81 KZ1100 is noisy when starting. Thought it was just mine. Maybe since they both are, it's normal.
ok well good, i will make a video and post it up and see what you think.
