1982 KZ1000 to Fighter..
  • Boostable
  • Boostable's Avatar Topic Author
Re: 1982 KZ1000 to Fighter..
20 Nov 2011 21:34 - 20 Nov 2011 21:42
#489387
Here you go... Didn't like the mount I was working on so I decided to go a different direction and had these pieces cut out at my local water jet shop. Guy says, do you have CAD file, I said.. sure do.. and handed him my 8.5x11 drawing, lol
Parts came out nice, and was done same day. I have a few other things I will be getting done for this project as well.
I will be adding two upper support as well from the center to the upper corners of the frame. Should be done this week with that.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
Last edit: 20 Nov 2011 21:42 by Boostable.
  • Boostable
20 Nov 2011 21:41
#489390
Here she is, rolling on her own now. First time out of the garage. I still have the rear end set as high as possible and will be lowering it with lowering lings. I just wanted to make sure I had the flexibility to raise or lower as desired.
~Jack
  • Boostable
20 Nov 2011 21:46
#489392
Teasing myself with some header fitting....
~Jack
  • ramtough_63
  • ramtough_63's Avatar
20 Nov 2011 22:00
#489393
looks great love the shock mount
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • bearshawk
  • bearshawk's Avatar
20 Nov 2011 22:56
#489398
man thats lookin nice!
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and pods :)
1998 honda superhawk 1000-fun in the twisties :)
1982 kz1100 A2 shafty, current project
  • camaroguy
  • camaroguy's Avatar
21 Nov 2011 07:29
#489457
bike is looking good. looks like you may have to raise your rear master to lower the pedal.or bend pedal down?what kind of pipe is that?
  • Boostable
21 Nov 2011 09:40
#489460
Thanks guys, I appreciate the comments. Its coming along nicely. Won't be long and I will be putting it back together permanently!!
camaroguy, Im not completely happy with the sets at this point. The pedal definitely needs to go down some. I will probably bend it down a bit, or I may make some plates that allow me to set it back and turn it down some. We shall see...
~Jack
  • Boostable
21 Nov 2011 09:42
#489461
sorry, forgot to answer your question. That is a Bassani pipe. :)
~Jack
  • testarossa
  • testarossa's Avatar
21 Nov 2011 09:57
#489463
Boostable wrote: Thanks guys, I appreciate the comments. Its coming along nicely. Won't be long and I will be putting it back together permanently!!
The roller looks good!
Let me offer you some advice on the rear sets. Looks like you have the same ones that I'm using. First off, don't decide on final position before you get the motor back in the frame and can figure out your shift linkage. It's gonna be tight between the shifter and the kickstand. Make sure to check it with the kickstand up and down. Also, the brake side may or may not have interference with the exhaust. Finally, you can adjust the brake pedal height a certain amount by moving that yoke on the master cylinder. It should be able to screw in or out a little and then you tighten that nut down on top of the yoke to lock it in place. I had to make up some adapter plates to position my rearsets where I needed them to be.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Boostable
21 Nov 2011 10:18
#489464
Thanks Test, that's kinda what I was thinking. It will be one of the last things I do to get the right fitment. I appreciate the advice!
Im working on some custom risers this week that you guys will like. Should be nice and adjustable if things work out like they should.. lol
I hope to have the frame fabrication all done within the next week or two, so that I can get it blasted and start putting it back together. Motor will be done fairly soon, so I need to get ready!
~Jack
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
21 Nov 2011 12:34
#489471
lookin good jack!
glad to be able to help out.
keep us posted,
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Nov 2011 20:16 - 03 Jan 2012 17:13
#489551
Lookin good man. B)
before u know it she'll be making noises all on her own.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 03 Jan 2012 17:13 by mark1122.
