Taking a dive! 82 KZ550 LTD Build
  • cte.matt
  • cte.matt's Avatar Topic Author
Re: Taking a dive! 82 KZ550 LTD Build
11 Oct 2011 01:01
#482492
Clutch, those wheels were actually pretty dirty. aaand after meeting the previous owner, i doubt he cleaned them. THey're blacked out now though.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
11 Oct 2011 01:03
#482493
Looks like it will work to me. Are you running a horn or turn signals? I didn't see those on there. Also, You may want to run a separate 10 amp fuse for ignition and one for lighting. If nothing else, it will help you track down faulty wiring easier if you have any issues.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • cte.matt
11 Oct 2011 01:05
#482495
Oh yeah, i forgot about the horn. Not running turn signals.
I was also considering putting a master headlight switch before the hi/lo beam switch. Will that work? DO you know what switches i should get?
  • clutch
  • clutch's Avatar
11 Oct 2011 01:09 - 11 Oct 2011 01:11
#482496
Also are you running indicator lights (oil pressure, neutral, etc)? They are easy circuits to wire, so probably don't need to be in the diagram. As far as switches, I recommend getting something easy to mount. There are some handlebar mount switches that are not too overpriced that are probably the easiest mounting. Main thing to be concerned with on switches is to be sure they can handle the load....I think most are rated for 20-25amp or so.
EDIT: yes it will work before the high/low switch
Wish List:
Last edit: 11 Oct 2011 01:11 by clutch.
