1979 KZ1000ST almost done
- Proxy
- 80% Human 20% Nuts/Bolts
Re: 1979 KZ1000ST almost done
05 Jul 2011 21:36
Preparing to run and duck for cover but I think it's one of the nicest looking AND I would prefer the shaftie. Solid looking sinister machine. You did helova job on her. You better be proud. She is a beauty.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
The following user(s) said Thank You: KZ250LTD
- trianglelaguna
06 Jul 2011 01:24
tight i like the black pipe and blacked out stuff.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- KZ_Rage
- Kentucky Bourbon Barrel Ale
06 Jul 2011 09:29KZ250LTD wrote: Thanks for the compliments! Yes, the stock carbs and airbox are going back on. In a few years when I have the money it'll be bored and flowed with CR carbs but for now I'm just going to ride.
My low profile filter cover arrived today so now I just have to install that, adjust the valves and my tank should be getting lined tomorrow and I'll get to see if she runs!
Curious as to what that looks like, please help the imaginatively impaired! :lol:
Brave indeed to have the tank lined just after getting that nice new paint work done. Mine was dipped and seems OK for the past 3 years but if rust ever shows up again I may go with coating it too.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
06 Jul 2011 11:18
wow! :ohmy:
you built a very nice machine.
i wonder how a paint matched zrx fairing and windscreen would look :whistle: .
keep us posted on the changes.
- Proxy
06 Jul 2011 11:37
I was just looking at it again. It is in the exact same position as the first picture you took. WOW! That is dedication to composition! Did you put tape on the floor to mark the position? Then I re-read it again. I see that is a photoshop. Any pics of how it turned out? I really like the plan!
- KZ_Rage
06 Jul 2011 12:48 - 06 Jul 2011 12:49Proxy wrote: I was just looking at it again. It is in the exact same position as the first picture you took. WOW! That is dedication to composition! Did you put tape on the floor to mark the position? Then I re-read it again. I see that is a photoshop. Any pics of how it turned out? I really like the plan!
The photos in the first posts are of what the bike looks like now if I'm following this correctly...
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
Last edit: 06 Jul 2011 12:49 by KZ_Rage.
- Proxy
06 Jul 2011 15:49
Ahhhhh! Thank you KZ_Rage. You have led this thirsty blind man to water. KZ250LTD You hit the plan on the head. Again, I say it is a very nice bike! Bring on the glamour shots!
- Kidkawie
- I bleed premix
06 Jul 2011 16:00
Nice job saving one! Looks great!
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- KZ250LTD
06 Jul 2011 21:53Correct! The photoshop was just up in my shop for inspiration/guidance along the way :lol:KZ_Rage wrote:Proxy wrote: I was just looking at it again. It is in the exact same position as the first picture you took. WOW! That is dedication to composition! Did you put tape on the floor to mark the position? Then I re-read it again. I see that is a photoshop. Any pics of how it turned out? I really like the plan!
79 KZ1000ST
Past:
Many.
Past:
Many.
- KZ250LTD
07 Jul 2011 02:45KZ_Rage wrote:KZ250LTD wrote: Thanks for the compliments! Yes, the stock carbs and airbox are going back on. In a few years when I have the money it'll be bored and flowed with CR carbs but for now I'm just going to ride.
Sure, the ELR kerker is designed for the later motor which has a somewhat different sump so the pipe came too close and was hitting the oil filter bolt.
APE sells a kit with a low profile cover, new filter bolt and new drain plug. The kit is designed for lowered drag bikes but works perfectly for this
Pipe is back on in the right place, also got some flat steel and cut out a new motor mount. The one which is on in the prev pictures is the end piece of the engine guards that were on it. It was thin and bent up so 1/4' steel should work better
79 KZ1000ST
Past:
Many.
Past:
Many.
- KZ250LTD
07 Jul 2011 02:56trianglelaguna wrote: tight i like the black pipe and blacked out stuff.....
Thanks craig, your MKII still outshines it though
79 KZ1000ST
Past:
Many.
Past:
Many.
- KZ_Rage
07 Jul 2011 09:29
Thanks for the visual! I see a couple of things are different from the MAC on mine, the clearance issue for one but the flanges are welded to the pipes it appears in the photo. Mine still use the Kaw collars.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
