76 KZ900 WINTER PROJECT
  • JEFFG1
  • JEFFG1's Avatar Topic Author
Re: 76 KZ900 WINTER PROJECT
30 Jun 2011 10:54 - 30 Jun 2011 10:56
#460273
( 531blackbanshee ) i will put more pics when i get home from work of front end thanks for your intrest
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
Last edit: 30 Jun 2011 10:56 by JEFFG1.
  • Sactown900
  • Sactown900's Avatar
30 Jun 2011 10:58
#460274
Good luck. I love the straight bars. Other than putting shocks on the back I would have left it as is. Maybe clip ons, 1200cc and an oil cooler.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
30 Jun 2011 11:55
#460284
z1kzonly wrote: Cool! That's my style also. I got you by 1 year. 53
Finish it, too. Not like me.
I have a similar project that has been sitting for 5 or 6 years now.
Then I started 4 other projects.
Rake the neck a little.
Bigger rear tire. Extend the swing arm. V/H sidewinder. Make only left hand turns :laugh:
Attachment not found
The ass end of that bike looks great! Is there a build thread on it?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • JEFFG1
01 Jul 2011 18:33 - 11 Jul 2011 21:58
#460523
Attachment MYBIKE015.jpg not found
Attachment MYBIKE029.jpg not found
Attachment MYBIKE050.jpg not found
Attachment MYBIKE052.jpg not found
Attachment MYBIKE055.jpg not found
ok now the front is done i started to mock the front and rear so if i had any changes it would not mess up the painted frame. they both fit fine. from what i have read on here i knew i would have to notch the frame so the chain wouldnt rub.other than that i cut the pass. peg braces so the swing arm would hit there also. didnt want to do that but i have them in case i want to build it stock some day.after mockup i started to strip it down and pull the motor also found a trick way to do this on (here) and it is alot easyer than trying to fight it out when it is in the uprite postion and that is i built a bow for the motor to sit in on its side then lift the frame off of the motor works great.
Last edit: 11 Jul 2011 21:58 by JEFFG1.
  • JEFFG1
03 Jul 2011 16:29 - 11 Jul 2011 21:59
#460773
Attachment MYBIKE074.jpg not found
Attachment MYBIKE080.jpg not found
Attachment MYBIKE083.jpg not found
now that everything was done i sanded the frame and painted it a single stage ppg brite black could of had it powder coated but i work at a body shop and paint is no problem.cleaned up the motor and painted it cleand up the chrome replaced all gaskets;cleaned carbs;the whole deal.added breather filter; oil press gauge and its ready to roll.
Last edit: 11 Jul 2011 21:59 by JEFFG1.
  • JEFFG1
04 Jul 2011 12:08 - 11 Jul 2011 22:01
#460932
Attachment MYBIKE084.jpg not found
Attachment MYBIKE085.jpg not found
Attachment MYBIKE071.jpg not found
Attachment MYBIKE092.jpg not found
Attachment MYBIKE087.jpg not found
Attachment MYBIKE090.jpg not found
now that everything is painted it was time to put it back togather this was the fun part watching your dream come to life.wireing harness and motor went first.i went to the rear next;i ordered a swingarm from D&G chassis to my specs 6" over 11" wide. went with a gsxr 6" wide sprad wheel wrapped with a shinko 190/50zr/17.had all bushings & spacers made used 39t sproket and gsxr caliber. wish i would have went with a 200 tire now that i see the room i still have when the 190 wears out i will:laugh: bolted it to the frame and i was done for the day
Last edit: 11 Jul 2011 22:01 by JEFFG1.
  • JEFFG1
04 Jul 2011 12:27
#460937
now that everything is painted it was time to put it back togather this was the fun part watching your dream come to life.wireing harness and motor went first.i went to the rear next;i ordered a swingarm from D&G chassis to my specs 6" over 11" wide. went with a gsxr 6" wide sprad wheel wrapped with a shinko 190/50zr/17.had all bushings & spacers made used 39t sproket and gsxr caliber. wish i would have went with a 200 tire now that i see the room i still have. when the 190 wears out i will:laugh: bolted it to the frame and i was done for the day
  • JEFFG1
04 Jul 2011 13:04
#460941
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
05 Jul 2011 10:28
#461116
nice progress!
keep us posted,
  • JEFFG1
05 Jul 2011 20:47 - 11 Jul 2011 21:53
#461197
Attachment MYBIKE097.jpg not found
Attachment MYBIKE091.jpg not found
Attachment MYBIKE094.jpg not found
Attachment MYBIKE096.jpg not found
after bolting the rear end on it was time to put the chain on.i went with a 5/8" offset 15t 530 pitch sprocket with a 38t rear, had to grind alittle of the inside of the sprocket cover space it about a 1/8" and that was that. next was the new v&h sidewinder header.this is where the problems started there was no real place to the bolt the back of the header & the brake lever was not going to work:angry: i have seen the way other people wrap the brake around the pipe and so on i didnt want to go that route, got to looking on ebay at brakes came up with the gsxr rears i already had the caliper on the weel so no brainer, it is all one unit brake peg all in one and it even had a brkt. to mount the pipe:laugh:with alittle work they fit great & work great also, problem solved. i also used them on the left side it came with linkage & pivet part that goes on the shifter shaft now both sides match. put a slick set of shocks on you will see them in the pics at the end of the build.now i know most of you see that there is no kick start but the bike starts & runs perfect so i didnt think twice.i put the frt.end on (no pics sorry) i put new h/lamp chrome ring - h/lamp mgts - drag bars- rt. & lft switches - grips polished every thing that was not new and it was a bone deal.
Last edit: 11 Jul 2011 21:53 by JEFFG1.
  • testarossa
  • testarossa's Avatar
06 Jul 2011 00:08
#461231
Ooohwee! Those engine covers sure are shiny. Wanna polish mine? :P Nice progress.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • JEFFG1
06 Jul 2011 08:38 - 06 Jul 2011 08:39
#461250
(testarossa) if i had any feeling in my hands & arms i mite help. thanks for looking, i was hoping someone would like the build. you know how much work goes into one of these. got to love it
Last edit: 06 Jul 2011 08:39 by JEFFG1.
