Son and I want to start this 76 KZ900
  • Sactown900
  • Sactown900's Avatar Topic Author
18 Jun 2011 13:40
#458020
Any tips on starting a stored bike?
I drained the tank and carbs 17 years ago. Once a year I would squirt oil on the spark plug holes and kick it over a few times for the rings and pistons. I changed the oil a few months ago and the new battery has been on a Tender Jr for the last year. My 26 year old son and I would like to get it running, put new tires on it and license it here in CA. I only paid $500 for it in 1993(?). DMV might be a chore. I have the signed bill of sale and transfer of owner, but never licensed it. It has not been started, since the original owner passed away 20 years ago. A friend who builds street rods said "change the oil, clean the tank with acetone, put in new plugs, gas it up and try to start it with a shot of WD40."
Any ideas on success stories would be greatly appreciated.
There are some awesome 900s on this site.
  • testarossa
  • testarossa's Avatar
Re: Son and I want to start this 76 KZ900
18 Jun 2011 21:21
#458083
Sounds like you have a pretty good plan. I would add one item on the To-do list. Install a small inline fuel filter in the fuel line between the tank and the carbs. That should catch any residual junk that might not get flushed from the tank. Should save you a lot of future headaches with those carbs. You are going to replace those old fuel lines, aren't you?
BTW that is a good lookin' bike to start with. It's definitely worth trying to get it back on the road. Perfect father/son project on this Father's day weekend. Get the legal stuff sorted out before you spend any major money to make sure you can get plates on it. Might look at new brake lines, flush and bleed the brakes, new pads, and probably a new clutch cable once you get it running.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Old Man Rock
  • Old Man Rock's Avatar
18 Jun 2011 23:55
#458116
IN case you need... FREE OEM Service Manual... 98% the same as yours...
Z1/KZ900 OEM Service Manual
Good luck
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The following user(s) said Thank You: payaso
  • supercharged
  • supercharged's Avatar
19 Jun 2011 01:45
#458139
CA titles are easy. I have used AAA to do all mine and they are great! Worst case is you will need to take the bike to the CHP for VIN verification.
If all this seems like to much a hassle... I'm available in CA to take that pretty bike off your hands ;)
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • Sactown900
19 Jun 2011 13:22
#458187
:ohmy: Thank you very much. Is your bike "build and start up" on You tube? It looks famileur.
  • z1kzonly
  • z1kzonly's Avatar
19 Jun 2011 20:11
#458226
Nice old school header. Looks like an aluminum akront 3.50" rear rim. Air shocks? Modern low rider!
I want that seat! old and not known!
Make sure you clean and adjust the points! Take the ign. advancer unit apart and clean and lube it.
leave the plugs out spin it over, use some compressed air to blow through the cylinders with the throttle open wide. Blow everything out, the exhaust and carbs. Many revolutions!
If it starts, take it out and beat er up! Up and down your street. Change the oil after 5 or 10 minutes too!
My opinion. Good Luck!
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
19 Jun 2011 21:45
#458241
Sactown900 wrote: :ohmy: Thank you very much. Is your bike "build and start up" on You tube? It looks famileur.
yeah that's Dave's bike on there. nice ride you got there by the way.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Sactown900
20 Jun 2011 17:36
#458377
Great tips. Thank you very much.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
20 Jun 2011 21:34 - 13 Feb 2012 18:21
#458424
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 18:21 by KZ250LTD.
  • Sactown900
21 Jun 2011 00:12
#458452
KZ250LTD wrote:
Sactown900 wrote: Any tips on starting a stored bike?
:whistle:
Yea, I think I may drain the battery trying to start this thing. Good thing the left knee is the bad one. :woohoo:
  • Nelson
  • Nelson's Avatar
22 Jun 2011 01:24
#458678
The back end looks low. Are those collapsed airshocks?
I'm guessing you're in Sacramento, me too.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • Sactown900
22 Jun 2011 12:00
#458715
Nelson wrote: The back end looks low. Are those collapsed airshocks?
Yes, I am Sacramento. Those air-shocks go empty in about 4 months. Part of my clean up (once it runs) is toss those for stock shocks and loose the front air valves, hoses and gauge. I see Z1Enterprise sells fork caps for $49.
You still own the bike in the avatar? It looks GREAT. I am going for the lowered-stock-sleeper look for now. My son wants me to build it like the WrenchMonkee Cafe Bike.
