Freebyrd's 81 KZ1000 Build
  • mark1122
  • Keep twisting it
30 Mar 2010 18:25 - 30 Mar 2010 19:26 #357313 by mark1122
Replied by mark1122 on topic 1993 ZX-9 Parts Bike
Does the mod i did makes sense in these pics..
if u look at the bottom of your tree, u can see how i had the boss drilled off, and a new thinner inner installed on mine. this allows the tree to sit 20mm. lower.Thus the front end raises 20mm.
[img][IMG]http://i575.photobucket.com/albums/ss198/markss01/KZ%20upgrades%2009/My%20front%20end/zx9tree1.jpg[/img]
[img] [IMG]http://i575.photobucket.com/albums/ss198/markss01/KZ%20upgrades%2009/My%20front%20end/96zx9toptree002.jpg[/img]
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 30 Mar 2010 19:26 by mark1122.
30 Mar 2010 20:08 #357349 by freebyrd24
Replied by freebyrd24 on topic 1993 ZX-9 Parts Bike
Makes sense to me! Good idea by doing that. It's also good to see these pics right next to eachother. Nice idea!
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
30 Mar 2010 20:19 #357353 by thompsonmx100
Replied by thompsonmx100 on topic 1993 ZX-9 Parts Bike
Wow your top triple is a lot different than mine. i have the 91 zx7 forks. My top triple is flat on the top and bottom at the stem hole. So if you find you want to lower your forks some it might be worth checking into some some of the other triples available for these forks. Mine looks the same as yours except for the stem mount area.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • mark1122
  • Keep twisting it
31 Mar 2010 03:08 #357387 by mark1122
What is the diameter of your forks at the top of each triple tree?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
31 Mar 2010 15:12 #357517 by thompsonmx100
They look to be 51-52 mm at the top.
1985 gpz750
Kz 650
01 Apr 2010 11:40 #357709 by 531blackbanshee
Replied by 531blackbanshee on topic 1993 ZX-9 Parts Bike
when mix and matching triples don't forget to check the leg to leg width and the offset from the stem to the legs.
fwiw,
06 Apr 2010 19:35 #358873 by freebyrd24
mark1122 wrote:
I was hoping you could find a pic of the stock top tree, to compare to the pic's i posted.
The post in front of my tank, is for a steering damper that i have yet to install.No time for my bike right now, and a Low priority.
This is the mount i used. it is from a 78 RM125, but there are many many others out there just search Ebay.
Maybe others can chime in here. i think the fat bars(1")have 7/8" handles so that they will accept the stock grips, and controls?
I have not checked the diameters myself. Am I looking for bars with handles that are 7/8" to fit stock controls?
Just an update, I found out a friend at work has a buddy who owns a machine shop :woohoo: so I think by the weekend I should have it back and should cost me a case of beer!
Sold:
  • porchev914
06 Apr 2010 19:56 #358875 by porchev914
Replied by porchev914 on topic 1993 ZX-9 Parts Bike
Buddies with/in machines shops are invaluable to those of us seeking enlightenment with the KZ spirit
FRANKEN Z!
06 Apr 2010 20:27 - 06 Apr 2010 20:29 #358884 by thompsonmx100
Sounds good. Just so you know if you were considering oversized mx bars they will fit 7/8 controls as they taper towards the ends. With that said they also leave little room for them. Enough though.Mark you say you got those mounts from a 78 rm? that doesn't sound right. The new bikes have just now started to come with rubber mounts. Unless they switched to solids then back to rubber.
1985 gpz750
Kz 650
Last edit: 06 Apr 2010 20:29 by thompsonmx100.
  • mark1122
  • Keep twisting it
07 Apr 2010 09:34 #358984 by mark1122
I bought the bar mounts on ebay. the lister could have been wrong about there origin?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
07 Apr 2010 09:53 #358987 by 531blackbanshee
i have a 1976 rd 400 and they have the bar mounts that were pictured.
07 Apr 2010 10:20 #358997 by freebyrd24
I was browsing ebay last night and there are a looooot of models that apprently used the same style handlebar mounts. For example there was one listed that looked the same for a CR250 from i think 1997. These mounts look to thankfully be veeeeeeery common!
Sold:
