Steve's Turbo KZ650
- S_J_H
Re: Steve's Turbo KZ650
10 Feb 2011 09:11
A few updates,
Most of the wiring is reinstalled. I'm going to replace the stock speedo and indicator lights with a KOSO db-02r and then I can finish up the wiring.
Turn signals and mirrors have been painted satin black fine texture
I made some port flange adapters for the carb manifolds. The adapters fit inside the kz1000 34mm carb manifolds. I blended in the ports on the head to the  large carb manifolds-
My trusty South Bend ready to turn the port flange adapters-
The finished adapters, Item on the right is a punch I made to cut the gaskets for the flanges.
The fuel system , It's about 95% right now.
A fuel shut valve is located just under the modified stock tank petcock. I just need to plumb in the return line from the regulator and line & filter from tank to the pump.
10 Feb 2011 14:03
nice little sb you got there.tidy shop to
what do the the adaptors do,make up for port size variation?
keep us posted,
keep us posted,
- S_J_H
10 Feb 2011 20:40
Thanks Leon.
The adapters are needed to mate the 34mm kz1000 manifolds to the small port 650 heads. The ID of the rubber manifolds is just about as large as the OD of the runner on the head. I did what I could so the inlet path beginning at the plenum box to the head is a fairly nice taper with no sudden steps. I'm hoping throttle response off boost won't be to lazy.
I also enjoy machining and cnc as a hobby.
My SB9 was a basket case when I got it and was ready to be scrapped. The cast iron journals in the headstock were badly scored. I line bored the headstock journals oversize and then made bronze sleeves for it. I used the carriage to move the line bore rig so the new journals would be bored true to the ways. The bed is worn but this old lathe still cuts to .0004" over 6".
Here's the rest of my little garage/shop where my madness takes place..
My 2 lathes, A SB9A and a really cool old Artisan 11x24-
A nice little drill press by High Speed Hammer-
A benchtop mill I converted to cnc-
I built this small cnc lathe from scratch a few years ago-
I started installing the dyna2000 kit tonight. It really is a nice ign system IMO. Good instructions and everything down to shrink wrap is provided in the kit.
- PLUMMEN
11 Feb 2011 06:01
11 Feb 2011 06:19
ah i remember you,:laugh: .
you have some very nice toys :woohoo: .
that little artisan is a work of industrial art.
now i know why your little 650 looks so sanitary.
if i am not being to forward,any guesstimate on what kinda money you have in your mill and cnc conversion?
- S_J_H
11 Feb 2011 10:43 - 11 Feb 2011 10:56if i am not being to forward,any guesstimate on what kinda money you have in your mill and cnc conversion?
Well I bought the mill new for around $900, A 4axis kit for 350$, Some ballscrew and nuts around $150-200 or so. Add in a few timing pulleys and belts for another $75 or so. I made all the mounts and bearing blocks myself. I think the above is a pretty good estimate.
It would be more if one had no material and hardware laying around but there's not much invested in the mounts and bearing blocks. I did not use angular contact bearings, I used a combo of deep groove and thrust bearings. Backlash is around .001" on the table axis.
I had a old pc laying around to run Mach3 with.
I already had a Mach3 license and cam software from a earlier mill I cnc'd.
It's been a very reliable machine. I think I cnc'd the mill around 5 years ago.
Yeah it was around 5 year ago, I found a thread I posted when I first built it, there's some pics and info here-
bbs.homeshopmachinist.net/showthread.php?t=20696
Last edit: 11 Feb 2011 10:56 by S_J_H. Reason: added more info
11 Feb 2011 11:24
thanks for the reply steve.
your little cnc machine's are perfect for building little trick custom pieces.
i have dreams about little machines like those working for me while i sleep :laugh:.
one of a kind one off pieces that could be duplicated exactly.(which would remove the exclusivity :dry: BUT ) :evil:
- S_J_H
11 Feb 2011 16:25
Yep it's a good little mill for small parts. It's work envelope should handle most things I'll want to make for the bike. I used it to make the plenum box. That was probably the largest thing I have used the mill for. It hogged out the 2"deep X 2.25" x 11" cavity from a hunk of 6061. I used this 2" reach 3 fluter-
Took a few hours to cut.
I installed the rest of the dyna2000 this afternoon. Wiring is my least favorite part of hotrodding anything but it has to be done.
I just need to time it and I can move on to the scavenge pump.
I don't suppose anybody has pics of a stock oilpump with the rotors out? I would like to see how the inlet and outlet ports are configured..
- rstnick
11 Feb 2011 20:52
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- S_J_H
- Marneman
12 Feb 2011 08:19
All I can say is....WOW! You have some mad skills my man. What a clean and impressive build. It sure will turn some heads.
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- OnkelB
12 Feb 2011 08:42 - 12 Feb 2011 08:44
S_J_H wrote:
Here's another one - click pic to enlarge:
Mad skills indeed, outstanding work.
...I don't suppose anybody has pics of a stock oilpump with the rotors out?...
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 12 Feb 2011 08:44 by OnkelB.
