KZ 650 Cafe/ Street Project
- benmorgan82
03 Dec 2010 12:42 - 03 Dec 2010 12:42Ok this is my first post and first KZ project. I am currently building a KZ 650 with a wiseco 810 kit. I ran across a set of spoked wheels with a 170 rear tire. So right now I am in the process of widening the rear swingarm to accept this wide of a tire. The plan is to put an inverted front end on it with the matching wheel. I am also in the market for some piggy back rear shocks. Let me know your thoughts.
Last edit: 03 Dec 2010 12:42 by benmorgan82.
- Mark Wing
Re: KZ 650 Cafe/ Street Project
03 Dec 2010 15:07
looks great so far, keep the pix coming.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- rstnick
03 Dec 2010 17:30
Welcome.
I'll be watching your progress.
Some like them stock, others with mods.
Me, I like em all, most of the time.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- benmorgan82
03 Dec 2010 17:58
Well I am a Harley person by trade but I recently became a motorcycle instructor and no longer can afford a Harley. I have grown to really love the look of a cafe style motorcycle. I like things clean and simple but different.
I am currently in the process of cleaning up the frame and getting rid of all of the none essentials. I am also having the engine powder coated. Not sure if I should stick with the stock gas tank or go with something different???
I am also going to make my own wiring harness, I hope??? I think I can manage but we will see. Just going to run a headlight and essentials for charging/starting. Luckily I am around it all day and have some very capable students to help in our down time. Hope to have it done by spring.
- testarossa
03 Dec 2010 19:16
Welcome! It looks like you are off to a good start. You need to get in contact with a member who goes by loudhvx. He has a bare bones wiring diagram that should help you out. So how much did you have to widen the swingarm to fit the 170 in there?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- benmorgan82
03 Dec 2010 19:59
What I did was trimmed the out side ends of the swing arm so that only the caps would fit on the ends( about 1/2 inch each side) then split it in the middle and got a 1.5 OD 1.334 ID steel tube and fit over each half of the swingarm. So long story short about an inch. But have not addressed chain yet so may be much more fab.
Thanks on the contact will do!
- z650c3
04 Dec 2010 13:54
I like your line of thought Ben , very interesting project to keep us all happy over the winter months. Keep up the good work.
c3
c3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
Northern Ireland
- benmorgan82
07 Dec 2010 15:29 - 07 Dec 2010 15:49
Alright made a little progress today. In this picture I show my swing-arm cut and almost ready to re weld around an inch wider. The pipe that I will slip over the middle part will be in tomorrow. I also have to mill out the axle grove to 3/4 inch to clear the new larger axle.
Last edit: 07 Dec 2010 15:49 by benmorgan82.
- benmorgan82
07 Dec 2010 15:31 - 07 Dec 2010 15:53
I cant figure out how to attach more than 1 different photo to one reply. So I will have to do separate ones
Last edit: 07 Dec 2010 15:53 by benmorgan82.
- benmorgan82
07 Dec 2010 15:51
In this picture I am showing how I put indention to add a little more clearance. I just lined up the tire and marked where it would be throughout the adjustment to add a little room. Just used a u block and a press.
- benmorgan82
07 Dec 2010 15:52
In this pic I am showing how we welded up the bracket on the front of the frame below the neck.I just like things as clean as I can get them. And I am actually mounting my voltage regulator on the inside of the frame with the fins pointing forward. I am trying to make the bike look as clean and simple as possible so most things will be hidden.
- rstnick
07 Dec 2010 17:48
Nice work on the frame and swingarm.
The stock swingarms were known to flex, and widening it and adding a bigger tire may stress it some more.
You might want to consider adding a brace to the arm.
I had a brace added to the bottom of a stock swingarm by a buddy:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
