Nelson's KZ1000 Fighter? build
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Nelson's KZ1000 Fighter? build
26 Sep 2010 21:30
#402156
i usually pull mine off in the fall and sandblast/repaint,so i get a season out of it pretty easy.
  • porchev914
  • porchev914's Avatar
26 Sep 2010 21:34
#402157
PLUMMEN wrote:
ive never used primer on a header,definately wipe it down with thinner before pain ting though B)
Thats solid advice before painting almost anything :)
FRANKEN Z!
  • Nelson
  • Nelson's Avatar Topic Author
26 Sep 2010 22:42 - 26 Sep 2010 22:42
#402161
Only a year Plummen? The primer's lookin pretty good now
:laugh:
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
Last edit: 26 Sep 2010 22:42 by Nelson.
  • PLUMMEN
  • PLUMMEN's Avatar
27 Sep 2010 05:49
#402192
im kind of an anal retentive prick about those things they tell me,so i repaint it whether it needs it or not :laugh:
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
27 Sep 2010 08:29
#402211
I recommend using 2 cans on the exhaust, I used one can on my header only and it rusted through within a week...
  • Kawickrice
  • Kawickrice's Avatar
27 Sep 2010 08:53
#402217
Those pipes get hot up towards the head. Unless it ceramic coated or something trick the paint will not hold on long, the megaphone may last but the downtubes will not. Plummens one year plan will make perfect since
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • racer54
  • racer54's Avatar
27 Sep 2010 10:52
#402249
One trick some use is to spray some high temp paint down inside the header pipes. Won't go too far obviously, but said to help keep temp down. Also should help keep pipe from blueing on chrome pipes if you spray temp paint down the header pipes. Put a good layer of paint in there...best to put on a few thin coats then empty the can all at once though.
  • Nelson
27 Sep 2010 18:39
#402335
I got the primer. I'd rather not do it every yr. if possible.
  • mjg15
  • mjg15's Avatar
27 Sep 2010 19:02
#402337
Go to Tractor Supply and get some Valspar Woodstove Paint. I just used it on my chrome Kerker and on the top end of my 550 project. Smooth, tough finish with just the right amount of sheen. I've seen it recommended on this sight before.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • trianglelaguna
  • trianglelaguna's Avatar
27 Sep 2010 19:40
#402345
i flat black my supertrap all the time while it still on the bike...tuck paper behind it and brush off the header withg fine steel wool......but it is a black pipe to begin with....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Nelson
27 Sep 2010 20:56
#402360
ooooh! aaaah! This is 1 coat of primer and 2 coats of paint. All VHT. It's still a bit wet in the pic, hence the shiny spots.
  • Nelson
27 Sep 2010 21:00
#402361
FYI- I shot the battery box with Rustoleum hi heat flat black just because I had it. I did not like the look, too chalky, almost whitish on reflections. It also marked up easily with the slightest touch. Glad I didn't use it on the pipe.
I fixed the battery box with a coat of clear.
