1977 KZ1000 new life
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: 1977 KZ1000 new life
05 Dec 2011 13:49
#491661
that new smaller battery will be a great space saver.
i have my battery box mounted sideways like that too. i have a conventional battery and it will not come out unless i unbolt the box and do a lot or wiggling to get the battery out then turned 90*. a bit of a pain.
Nice job.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • rslingshot
  • rslingshot's Avatar Topic Author
14 Jan 2012 20:00
#498089
Ok so today I got some motivation and did a little work, I finished mounting the battery box and made an inner fender out of some 1/8 aluminum plate.
First I welded a plate across the frame,this will keep every thing flat and even. Once I had the plate welded in I cut out the center to fit the battery box,Then drilled and taped 4 6mm holes to hold it down.
Then I took some cardboard and made a template for the inner fender, Once I had the basic shape I traced it out on a peice of 1/8 aluminum plate. Cut that out and took a grider with a flaper wheel and shaped it to a good fit inside the frame rails. Then I took some 1/8 inch flat bar and made some mounting tabs for the fender. I split the differnce of the dia of the frame rail tubeing so the fender would sit in the center of the inside of the frame rails. All in all it turned out ok.
  • ramtough_63
  • ramtough_63's Avatar
14 Jan 2012 20:43
#498092
sweet job.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
16 Jan 2012 11:06
#498283
looks good.
a little closer :evil: .
  • rslingshot
16 Jan 2012 18:41
#498359
Thanks guys, it felt good to put some time in on the old girl this weekend it has been awhile, I worked so much through the holidays havent had any time to work on it. I am trying to get all the frame welding done this month so I can get it out to the powder coater. Then I can finish up all the machining of the covers,and custom parts I need to get done, this project has gone on to long and I have another kz1000 behind this one. DOES IT EVER END!!!!!!!!!!!
  • 531blackbanshee
  • Vendor
  • Vendor
17 Jan 2012 10:40
#498435
it does end,
sorta.
well,i mean that you get to a point to where there is ride time in between :lol: .
  • Nelson
  • Nelson's Avatar
26 Jan 2012 02:29
#500125
ya I'm really looking forward to somma that ride time myself...
Luv that battery box!
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
The following user(s) said Thank You: rslingshot
  • rslingshot
30 Jan 2012 20:28
#500946
So I am sitting in the shop just looking at my inner fender and I was not happy with it, it needed to drop down to cover the battery and a little of the shock to keep some of the road crap off. So I bent a peice on the table and got the angles that I was looking for and welded it to the first section. It worked out ok I can still remove it easy, after it is powder coated it will look ok. My sheet metal skills are weak as hell so I know that I could not bend it in one shot, so it is what it is.
  • gengomerpyle
  • gengomerpyle's Avatar
30 Jan 2012 20:33
#500949
nice work
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
30 Jan 2012 20:34
#500950
i think your metal bending skills are a lot better than u think, my friend.
B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • rslingshot
30 Jan 2012 20:40
#500952
mark1122 wrote: i think your metal bending skills are a lot better than u think, my friend.
B)
Thanks Mark,Trust me they are weak I just got lucky. LOL
  • ramtough_63
30 Jan 2012 20:49
#500955
That looks great. nice work
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
