KZ1000ST CAFE monoshock new rear end
  • greenmeany
  • greenmeany's Avatar Topic Author
09 Aug 2010 13:05
#389639
I tried to edit my last thread and add osme pics, but it looks like there is no edit feature, so I started a new one.
Shortened the seat by about 6 inches and rearranged the electronics and tail light setup in an effort to make this bike look a bit smaller and not so tail heavy. Let me know what you think:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: KZ1000ST CAFE monoshock new rear end
09 Aug 2010 13:27
#389648
Well i certainly dont think it looks tail heavy.
if anything it looks tank heavy .LOL :laugh:
it sure looks good.
B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
09 Aug 2010 19:02
#389756
Looks great to me.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • melkweg
  • melkweg's Avatar
09 Aug 2010 19:36
#389768
Looks fine to me aswell. Thats the first time I've seen anyone get that style of silencer to look good. The one little thing is that the tail light looks wrong to me.
  • larrycavan
  • larrycavan's Avatar
10 Aug 2010 05:16
#389837
It's the coolest shaft drive KZ I've ever laid eyes on :)
  • Old Man Rock
  • Old Man Rock's Avatar
10 Aug 2010 05:29
#389839
No doubt... There's nothing I don't like about it... Looks clean, attention to detail as far as these images provide, everything's all tucked in nice and neat & she just looks freaking awesome... Well done! ;)
Now, how about some close up around all those purdy mod details you have going on there... :cheer:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
10 Aug 2010 06:25
#389854
bike looks very nice and balanced.
how bout some left side pics tho?
  • greenmeany
10 Aug 2010 07:19
#389870
Ask and ye shall receive. Some of these are prior to me shortening the seat. Bike still has dual exhaust on it and cateye tailight. Also, the swingarm isn't quite finished in these pics
  • sean311
  • sean311's Avatar
  • 2 wheels, 4 cylinders and 1000 cc's
10 Aug 2010 11:29
#389906
wow thats very clean! what swingarm did you use and how did you make the tail piece?
  • greenmeany
10 Aug 2010 11:41
#389910
Swingarm is modified stock. The tailpiece(seatpan) is made by Airtech
  • testarossa
  • testarossa's Avatar
10 Aug 2010 11:52
#389912
I like the shorter rear end. That bike looks mean. Nice work. I'm sure you probably said in you other thread, but where did the rear shock come from?
No puddles for you. That short rear will keep your back wet.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • greenmeany
10 Aug 2010 12:11
#389914
yeah right! i try not to ride in the rain if I can help it, not a pleasant time.
The rear shock is a Showa nitrogen unit off of a 2006 Ducati 999, fully adjustable for rebound/compression damping, and preload.
I would have to agree that the shorter rear end gives it a pretty mean look, now I just need to get some wider rubber on the rear. Not the easiest thing to do with a shaft drive bike. The plan is to eliminate the part of the swingarm that covers the drive shaft, and use 2 seperate pipes of a smaller diameter instead, one over the driveshaft, and one under, leaving the driveshaft exposed, which I think will look pretty cool. Something along these lines:
I have a rear wheel from an 08 R6 that i am going to try to adapt to shaft drive by removing part of the hub, then welding on a machined adapter that will allow it to mate to the drive hub. The swingarm will not be a problem, that is a pretty straight forward endeavour. Getting a 6 inch wheel to work is another issue entirely, although i do have access to a CNC mill and someone that knows how to use it, so i think it is do-able. I would be happy if i could get a 160 series rear tire to fit in there, although a 180 or 190 would be badass!
