1979 KZ650 Restoration
- DoubleDub
Re: 1979 KZ650 Restoration
03 Apr 2010 23:02 - 03 Apr 2010 23:04
Thanks! Store names sounded familiar
I've never cleaned up engine components like this, how do you dry them after using the power washer? Just ambient evaporation?
Last edit: 03 Apr 2010 23:04 by DoubleDub.
- porchev914
03 Apr 2010 23:20
I know this won't really help, but I had my engine castings blasted at a local deburring polishing shop. They wouldn't tell me their exact process, but they started with glass beads and I THINK they finished with plastic media (found a piece wedged in the crankcase). My engine parts look 1000% better because of those guys
From this-
From this-
FRANKEN Z!
- porchev914
03 Apr 2010 23:21 - 03 Apr 2010 23:24
FRANKEN Z!
Last edit: 03 Apr 2010 23:24 by porchev914.
- kzmk2
04 Apr 2010 20:49
porchev914 your castings look awesome!! It would be interesting to know the process they used. This would not have helped on my project, this will be 100% DIY.
- kzmk2
11 Apr 2010 21:29
Took friday afternoon off because the weather was so nice to paint the frame on the 650. The painting went pretty well, Now I feel like I am on the downhill run of the project. Here is the painted frame on the rotater in the paint booth.
- kzmk2
11 Apr 2010 21:34
Today I got a chance to do a little bit of assembly. I installed some new tapered roller bearings in the steering head. Installed the rebuilt, polished and clear coated forks and front wheel. Installed the rear fender and inner fender. I even put the reflectors on for some reason, safety first I guess.
- bill_wilcox100
12 Apr 2010 08:10
Looking good! Very inspirational.
Best of success,
Bill
Best of success,
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- porchev914
12 Apr 2010 15:43
It always feels good to start putting things together. What did you end up doing with your engine case reconditioning?
FRANKEN Z!
- kzmk2
12 Apr 2010 19:01
I am sticking with the glass bead blasting. I hope to have the engine bottom end assembled this week. I was waiting for a crank seal to get here and it finally did today. I'll post some pics of the assembled engine. Where did you get your cases done? I might be interested in going that route on my next project.
- DoubleDub
- kzbobber2
- 1980 kz650
- kzmk2
15 Apr 2010 11:03
I used Valspar Gloss Black with Valspar hardner. The hardner makes a HUGE difference in the paint. It improves the gloss finish by a factor of 10. I used it on another motorcycle frame and was happy with it, so I thought I would use it again. It is a very low cost solution, I think the paint and hardner cost less than 20 bucks. When using the hardner you do have to take additional safety precautions, you have to have good ventilation and a good respiratior. If I were doing a Z-1 or refinishing my MKII I would probalby use a higher end paint, but I do not want to put a fortune into this 650.
