Testarossa's 78 KZ1000 Fighter Build
- camaroguy
Re: Testarossa's 78 KZ1000 Fighter Build
17 Aug 2010 02:35
Frame is looking real good.looks like one big piece of flowing steel tube. youre cranking on that thing.you must be seeing real light at end of tunnel.cant wait to see it as a roller all purdied up.
- trianglelaguna
17 Aug 2010 08:29
that be alrite
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
17 Aug 2010 11:43
testarossa wrote:
No problems so far. i'm sure the bond will flex that much, just like the paint does. just put some nice stainless washers between all bolts and paint. without a washer the paint can chip during tightening of the bolt.
Mark, how is your bondo holding up in those welds? I'm scared of using too much filler. I would hate to have a chunk of filler pop out when the frame tries to flex. If anyone can make it flex it's gonna be me.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
17 Aug 2010 17:42
Thanks for the tip Josh, I checked and there is a Fastenal localy. I was in H.F. today, and they sell them too, but they're just as expensive there at $1 apiece! :blink: I think I'll pay a few extra cents and get the 3M brand ones :dry:
FRANKEN Z!
- porchev914
17 Aug 2010 17:48
mark1122 wrote:
Plastic body filler is pretty flexible stuff. It won't withstand concentrated compressive loads well (bolt tightened against it for example) but it is especially designed to bond to steel and flex with sheet metal. I'm certain that the bed side of a truck quarter panel flexes much more than our frames do, and I've put barrels of bondo on them :laugh: If you needed to cheat with some body filler to smooth out some hard (or impossible) to reach areas, IMO, it shouldn't present an issue in the future
testarossa wrote:Mark, how is your bondo holding up in those welds? I'm scared of using too much filler. I would hate to have a chunk of filler pop out when the frame tries to flex. If anyone can make it flex it's gonna be me.
FRANKEN Z!
- testarossa
17 Aug 2010 20:18
Should I hit the areas to be filled with a coat of epoxy primer before I use the filler? I would like to fill some of the smaller imperfections. It's a lot easier to even that stuff than running another bead, and filing/sanding the steel.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
17 Aug 2010 20:40
No, the filler will adhere best to bare metal. Hit the area you want to put the filler with 24-50 grit (what ever you have available) The epoxy primer is not a good primer filler, so you'll want your body filler/steel finished with about 320 or so....I think. The can of primer will say what grit to finish your substrate to, follow it as best you can
FRANKEN Z!
- testarossa
17 Aug 2010 21:11
Roger that. 36 grit, then filler, then prep according to the tech sheet.
I'm not sure how much more work I want to put into prettying the frame. I question my sanity every time I start working on a weld. I have already given myself tendinitis in my right elbow. Sometimes I think that I may have a touch of OCD. I could have just painted the frame and 99.44% of people would never notice. I guess that it is my calling card, and I can't do it any other way. Unfortunately I'm putting a $15,000 effort on a $3000 bike.
Don't take it the wrong way. Sometimes the voices in my head have to speak up. :ohmy: I'm not griping about what I have to do, I wouldn't build it if I didn't enjoy the work. But my elbow does hurt.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
17 Aug 2010 21:11
mark1122 wrote:
ya cant chrome bondo! :laugh:i cheated and use bondo.
Nice job.
- porchev914
17 Aug 2010 22:03
1 more thing Josh, DO NOT KILL YOURSELF trying to go over the entire frame with 320 or whatever the PPG recommends for the epoxy primer. It is more important in the areas where you have filler. 100 grit will not leave nearly the scar on the steel frame as it will on the bondo, so finish your filler spots with the recommended grit. The frame will be fine with a 120 or 180 or whatever finish you've got on it. If your worried about grinding scratchs showing up, test spray a spot of the frame. If it needs more work, do it, if not, spray away
FRANKEN Z!
- testarossa
18 Aug 2010 07:47
PLUMMEN wrote:
True, but you couldn't pay me to chrome this frame.
mark1122 wrote:ya cant chrome bondo! :laugh:i cheated and use bondo.
Nice job.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
18 Aug 2010 07:51
porchev914 wrote:
Thanks again for the good advice. I have painted some steel parts that were sanded to 120 before, and they looked good to me. Actually my original plan was to fix the fillets, and then sandblast everything one last time to even out the finish. I realize that I cannot blast any areas that I have used plastic filler. We'll see...
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
