Testarossa's 78 KZ1000 Fighter Build
  • testarossa
  • testarossa's Avatar Topic Author
Re: Testarossa's 78 KZ1000 Fighter Build
09 Oct 2010 18:19
#405559
Check out what this Wookie sounds like:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
09 Oct 2010 18:35
#405567
What section do you find the swing-arm spools in???
I'm going to HF tomorrow...today is my b-day and I gots me sum money to blow!!!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • testarossa
09 Oct 2010 18:50
#405571
The same aisle where I found the slide hammer IIRC. They have about an 8' section that has a rear stand, the spools, stand adapters, wheel chocks. That aisle was right in the middle of the store. Click the link to see them: www.harborfreight.com/automotive-motorcy...ifts-stands.html?p=2
2004 ZX-10R
Angola, IN
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
09 Oct 2010 19:19
#405579
Brilliant! Thanks for the scoop! I'm going tomorrow!
CHEERS!
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
  • T_Dub
  • T_Dub's Avatar
10 Oct 2010 04:22
#405623
Thats kick-ass Josh! I really like the back indicators too.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • porchev914
  • porchev914's Avatar
10 Oct 2010 10:07
#405663
PLUMMEN wrote:
porchev914 wrote:
Back in the day (and not on fuel tanks), we would just punch holes in a panel, screw in the slide hammer and pull out the dent. Then weld up the holes with a mig and apply body filler. The boss didn't believe in a tool that used proprietary consumables like studs. A stud gun would be cool, and if you have alot of dents to pull out in your Mustang, it would be cleaner and faster. But for one dent in your tank, I stand by my initial recommendation........
Buy a carbon tank :laugh: :laugh: :laugh:
do you know a suplier of cf tanks? :woohoo:
No, as a matter of fact I do not :pinch:
The light looks good Josh, and she starts right up and idles smooth. Thats' gotta feel good!
FRANKEN Z!
  • testarossa
11 Oct 2010 06:26
#405921
You are right Adam. It does feel good. Now, yesterday I got my tank bung welded in place and the old bung was removed and sealed up. I had two small leaks initially upon water testing. Once the leaks were sealed, I finally got the Pingel installed. I also welded a small bolt in the center of that dent and pulled it most of the way out with my new slide hammer. That's the last bit of welding to the tank, so I can actually use it now. If I had it to do over again, I would just hold out for a proper KZ1000 tank. This tank was a PITA to fit, but it's done.
I also changed the pilot jets to 17.5's. Time for some more laps of Bridgestone West.
2004 ZX-10R
Angola, IN
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
11 Oct 2010 11:17
#405976
where were the air screws set at with the 20 pilots? how many turns out ?
the bike sounds great. well done. B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
11 Oct 2010 11:44
#405980
i wish i would have saw this before you started on that tank. you should not start at the center but at the outside edges then work your way inward. it works out better and less repair afterwards
  • testarossa
11 Oct 2010 13:15
#405997
That's a good tip. It's no matter, the remainder of the dent will be corrected with filler. I just didn't want filler that was 1/4" deep. I'll keep that one in mind for the next time I pull a dent.
Mark, the screws were at 1 1/4 turns out from seated. I have the screws that are on the engine side of the carb. I suspect that this will change with the smaller jets. I doubt that I can fool with it today. I'm committed to catching up on car maintenance. Oil changes all around, and sadly the Miata needs a throwout bearing.
2004 ZX-10R
Angola, IN
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
11 Oct 2010 14:08
#406011
ew i have heard that the exhaust and driveline has to come out before you can get the tranny out.is that true?i heard it was a b!t(h.just curious and i figured you would know.good luck on the auto's hope everything goes smooth.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
11 Oct 2010 19:39
#406053
Well, as long as you are that far into the Miata....
www.bossfrog.biz/Miata_V8_Swap.html
