A little bit of an upgrade...
  • Bdog
  • Bdog's Avatar Topic Author
  • Sweep the leg johnny!!!
Re: A little bit of an upgrade...
02 Jan 2010 17:41
#341639
moving the kickstand, again. For a different rearset position.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • Bdog
22 Mar 2010 17:44
#355496
Ok, so I'm back at it and I have gotten the swingarm bushings, the lower shock mount and teh upper all made and after all that I can't figure out the picture transfer from my old camera. So, I will post up soon.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
  • Bdog
16 Sep 2011 12:30
#477272
Well it has been a while since my last post. I will add a few details and one more photo for now. I have to complete my footpeg mod, wiring harness, get 1/8" shaved off the rear sprocket carrier, buy a chain, and get brake lines. That is the shortest list this bike has had in a while.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
  • T_Dub
  • T_Dub's Avatar
16 Sep 2011 13:02
#477278
Thats one of the cleanest monoshock installs I've seen, not overdone like a lot of them. Great looking bike.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
The following user(s) said Thank You: Bdog
  • Bdog
16 Sep 2011 13:47
#477286
Thanks, I himmed and hawed over how to do it several months and then it was just getting the ride height correct. I will add a side view of the bike soon and show the ride height. It is real close to how it used to be with the twin progressives and aftermarket swinger.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
  • Bdog
16 Sep 2011 14:21 - 16 Sep 2011 14:44
#477292
Now if someone could tell me the size and pitch of the stock footpeg mounting bolt on the '77 650 I could get started on finding a longer one to accomadate the brake lever I want to use. Hehehehe, this one is going to be really cool.
Thanks in advance.
Nevermind, I just put this computer to good work and got the 12mm bolt ordered from fastenal.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Last edit: 16 Sep 2011 14:44 by Bdog.
  • T_Dub
  • T_Dub's Avatar
16 Sep 2011 14:46
#477294
Its an M12x40mm bolt, not sure of the pitch but it aint big, maybe 1 or 1.25.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • Old Man Rock
  • Old Man Rock's Avatar
16 Sep 2011 19:58
#477335
You have our attention!!!! B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
16 Sep 2011 20:57
#477346
Yep!
Keep up the cool work.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • Bdog
19 Sep 2011 11:20
#477848
Soo I was reading a bit here and there and most everyone is NOT running an oil cooler for a basic big bore (Wiseco 810 10.25:1 comp)? If that is the case I will not continue running the Derale on mine. That does beg the question of way Daddy Kaw put one on the GPZ750?
Well I picked up a 2x4 sheet of ABS for bending into the undertail and to mount the battery under the seat.
I am still not 100% on the small headlight, but it was given to me the last night I saw an old biker buddy of mine. He was a very cool fella, so I feel like that may be the 'chooper' part of the bike, or something. Any way I will get more photos up soon, a little bit more welding to do for the underseat tabs and rear brake master and a coupla more bushing to have turned. I guess it will be next year before I can ride her, legally. ;)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
  • T_Dub
  • T_Dub's Avatar
19 Sep 2011 11:23
#477849
The advice that I was given from Lorcan, the resident 750 turbo master, is that he doesn't run an oil cooler on his 200hp turbo 810cc bike, and he doesn't have any temp issues. Of course he runs his bike in England, which isn't extremely warm in the first place. I live in Newfoundland, which is even colder, so I elected to do without the cooler. As long as my tuning is good and I'm not leaning out, I should be fine.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • Bdog
19 Sep 2011 19:30
#477932
Well the bolt from Fastenal was a 1.75 pitch, but the length is right. Soooooo, now the hunt continues and I am afraid that I will have to have a $2 bolt get shipped for $8-9. I will try a local spot tomorrow that usually has a little of everything. We'll put that to the test.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
