begining of my 650 build
- hardr0ck68
- Who put the what in the where?
Re: begining of my 650 build
22 Oct 2009 19:53
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- hardr0ck68
22 Oct 2009 19:54
1977 kz650 c1
- hardr0ck68
22 Oct 2009 19:55
Anyone interested in the jack hole who sells crappy parts send me a PM I will gladly share his name.
1977 kz650 c1
- hardr0ck68
22 Oct 2009 19:57
and the gear wear... If it was just for this I might use the trans; but then again I want it to be a solid bottom end not something I need to re-visit in 2 years.
1977 kz650 c1
- Mark Wing
22 Oct 2009 20:06
So what clutch would you use with that 6-speed trans?
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- thompsonmx100
22 Oct 2009 20:09
That sucks but that is cool that trans will fit. I too have been sold garbage on ebay. I am build ing a bike pretty much completely assembled from parts on ebay. i have had to send a part back no biggie ther but then i bought a set of brakes that did not come with everything shown in the pics i got a partial refund but i should have gotten more cause the mount bolts were next impossible to get. keep it up
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- hardr0ck68
22 Oct 2009 20:15
Mark Wing wrote:
I am not gonna lie; I did not even think of that till you asked. I guess the answer is, which ever one seems better to use
I have a friend who does amazing work... so if something needs to get machined I will call him. I am hoping the kz basket will fit...but it very well may not. Maybe now is the time to start thinkin about one of those new fancy slipper clutches all the sport bikes run :blink: :lol:
Mark
1977 kz650 c1
- Mark Wing
23 Oct 2009 09:13
I was just wondering because I have a hopped up 650 with lots of work done and I run a 17 front sprocket and I'm always looking for another gear when I'm on the freeway. I like the idea of a 6 speed, I tried a GPZ550 trans but couldn't get it to work with the cases torqued together and I would have had to use the 550 clutch.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- hardr0ck68
23 Oct 2009 09:22
Yes I remember reading your threads on the old forum.
I am HOPING the tranny you got had a bent shift fork, but I will probably be measuring everything and trying to find what causes the throuble shifint into 6th.
Did you use the shift forks from the 650 or the 550? The zx600 and kz650 shift forks are clearly different. But if I had to bet I would say you knew that already... I hope yours was a fluke issue, but I am prepared for the worst.
Next on my list, pull the nutral finder out of the zx600 tranny so I can try shifting through the gears.
1977 kz650 c1
- Mark Wing
23 Oct 2009 21:55
I'm pretty sure I used the 550 shift drum and forks, I don't think it would work other wise. It would go into all 6 gears with the cases still split but not with the cases together. Man I hope you get it to work cause I'll be adding one to my motor too. Good luck and keep us updated on your progress.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- timebomb33
24 Oct 2009 11:35
is there something in the case half's that needs to be relieved may be something in the way of shift fork travel.
I THINK MY POWERBAND BROKE
- hardr0ck68
25 Oct 2009 20:35
Mark, are you still reading this??
How much of the motor was together when you torqued it all down and found the problem??
I just got the correct bearings and caps swapped around tonight to make it all fit nice (the input shaft end cap are different, and to swap it I needed the cap from the 650, the needle bearings under it and a washer under those needle bearings all from the 650) I can take pictures to show the parts I swapped if this all works.
then I put the otherwise empty cases back together and put the inner sprocket cover on; tossed in a half dozen bolts and tightened them up.
THE BUGGER WORKS! all 6 gears change easily.
But I wonder, maybe a part that I will install later will cause the issue... but the mock up seems to work well. Pic's tomorrow.
1977 kz650 c1
