begining of my 650 build
  • hardr0ck68
  • hardr0ck68's Avatar Topic Author
  • Who put the what in the where?
Re: begining of my 650 build
08 Oct 2009 17:58
#326271
drained the oil, pulled the pan and took the jugs off.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • hardr0ck68
08 Oct 2009 17:58
#326273
that slude is not tooo bad, ;)
1977 kz650 c1
  • hardr0ck68
08 Oct 2009 18:00 - 09 Oct 2009 08:32
#326274
I did some damage to the jugs getting them off, there was some kind of sealer on the base gasket... I am sure it will be fun to scrape!
1977 kz650 c1
Last edit: 09 Oct 2009 08:32 by hardr0ck68.
  • hardr0ck68
08 Oct 2009 18:01
#326276
Does anyone know if that damage with cause a problem?
Also what are the hard rubber plugs for? where they for any thing important? One is missing and one is so brittle it will not stay in!
1977 kz650 c1
  • Kawickrice
  • Kawickrice's Avatar
08 Oct 2009 18:36
#326287
Looks like you are ready for the fun to begin. Nothing like rebuilding in the house, the beer in the fridge is close. Reminds me of rebuilding a small block chevy in my livingroom when I got rid of my first wife, and had a batchlor pad.... Those were the days.... Keep the pics coming too
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • PLUMMEN
  • PLUMMEN's Avatar
08 Oct 2009 18:40
#326291
  • kawsakiman
  • kawsakiman's Avatar
09 Oct 2009 07:59
#326372
the plugs are nothing. they stop the wistling noise when crusing. you can remove them with no ill effects.
i'll swap cranks with you when you get back if you want.
  • hardr0ck68
09 Oct 2009 08:36
#326378
Great, I will just clean up the smashed plug hole, and put all 4 of them back in place with some high temp rtv.
The jugs will need some cosmetic repair as is, I have a friend who I hope will tig that broken fin up for me in exhange for some beer.
Thanks for the offer of the crank. I will be home for Thanks giving weekend, if you want to meet up some time then. I want to use the gpz head so the hyvo chain seems to be the way to go...
1977 kz650 c1
  • hardr0ck68
18 Oct 2009 06:58
#328182
Some more progress; this was as far as I had ever been into a kz motor before...
1977 kz650 c1
  • hardr0ck68
18 Oct 2009 07:00
#328184
Got the cases split... I need an impact to pop the clutch pack off the tranny. Or maybe this is an excuse to buy a 750 turbo clutch "you see sweet heart, it is stuck on, i need a new one!"
1977 kz650 c1
  • hardr0ck68
18 Oct 2009 07:01
#328185
bottom case;
1977 kz650 c1
  • hardr0ck68
18 Oct 2009 07:04
#328188
I did make a mistake while tapping the starter clutch out.... I did not remove the locating plate that holds it in place on the clutch side. I warped the plate, running the part number on google shows me 2 or 3 retailers who sell it for less than $10. So I am in luck
1977 kz650 c1
