KZ900 A4 in kansas
- Krusty_47
Re: KZ900 A4 in kansas
25 Mar 2011 21:46
Ok so here are some pics of the mounts as they stand right now. I'm pretty sure we are going to change the setup and just widen the frame and putting them back into the stock location.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
- wireman
25 Mar 2011 21:53
can you narrow the pivot on swingarm instead?
- Krusty_47
25 Mar 2011 22:07
While that is an option I don't think I would be able to and keep the wheel on the center line and cut off the right side of the swingarm mount. I'm not very rushed on this so I'm going to get the front forks mounted next weekend and then I can see what I can do to mount the swingarm. I also have to consider chain clearance against the frame. The one thing that sucks about this swingarm is that the chain rider right down the left side.
The black rubber on the far side of the swingarm is the chain protector where the chain runs. Where it's mount now would rub against the frame. That's why I think widening the frame is the best option at this point.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
28 Mar 2011 15:21
keep us posted on your progress.porchev and stu pidasole have both widened their frames.
can't wait to see how it turns out for you.
- rslingshot
28 Mar 2011 17:45
Here is a couple of pics of a single sided swingarm fitting into a 89 gsxr which I know the 89 gsxr swingarm fits the kz so the sss can be made to fit the kz frame also without cutting and widening the frame. Just cut the swing arm on the right side remove the material you need to fit and weld it back up.
- testarossa
28 Mar 2011 17:59
How the hell did I miss this thread? Well Krusty, looks like you have a good plan, and I like the VFR swinger and wheel. How much wider is the swingarm than the frame? If you plan on widening the frame, make sure to jig it up so everything stays straight. See porchev914's post, I know you have.
BTW my condolences on your father. I know it's been a while, but I lost my dad back in 2004, and I know what you are going through.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Krusty_47
28 Mar 2011 18:44
Yeah it was tough but my family got through it.
As for the width difference...We are talking less than half an inch. I will see about just cutting off that amount from the right side of the swingarm and see if it would line up right but I have the feeling it might not. I'll keep you all posted with pictures and write-ups as they come along.
And I have read through Porchev's thread about 4 times now. And I'm sure I'm not done reading through it.
Right now the rear wheel is lined up perfectly with the front but the chain would hit the frame the way it is now. I plan on jigging it up and widening the frame the all of 1/2 an inch I need to fit it in there and line it up correctly. That won't be for a couple of weeks as it's soccer season for the kids and we'll have 3 games every Saturday. Although I will have pictures of the front fork and tripple tree on the bike this weekend.
Thanks for all the support and suggestions. We'll see how everything pans out. And don't worry there will be updates.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
28 Mar 2011 19:00
DONT CUT YOUR FRAME!!!!!
i did, and regret it. if anyone recommends cutting your frame give em a slap for me!
leave that damn frame alone, modify the swing arm. i would buy a diff frame, and modify my arm, but i have tons of hours in my frame allready. be smart.
- Krusty_47
28 Mar 2011 19:32
I'm going to do everything I can not to cut it. I would really rather not do that but I may not have a choice to get that wheel centered on the bike. I have no intension on cutting the frame at all. It's such a small difference that I may just jig it up and push the frame out the less than an inch I need. Put in the proper support and then put a torch on it to release the tension. Although, I am going to be taking a good long look at the swing arm and see what I might be able to do it it and make it work.
On the lighter side of things. I just got my new tapered steering bearings in today. I also just got done speaking with Proxy and picked up a Corbin Gunfighter on the cheap. Thank you so much Proxy.
So thinks are going as smoothly as they can and I can't complain at all.
If you don't mind me asking though Stu. Why are you so unhappy with the frame the way you did it?
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
28 Mar 2011 21:36Krusty_47 wrote: I'm going to do everything I can not to cut it. I would really rather not do that but I may not have a choice to get that wheel centered on the bike....
Centerlines of front tract and rear track should be parallel, but need not overlap.
- Stu Pidasole
28 Mar 2011 21:37
"If you don't mind me asking though Stu. Why are you so unhappy with the frame the way you did it?"
im ganna be honest. cutting it seemed easier at the time since i can weld/fabricate. easier dosnt meen best solution. when i cut the bottom brace/rear motor mount cross tube and spread it, the pivot was not square. i had to make more cuts to square the frame. if i was to do it all over again, i would modify the swingarm no doubt. i hope it all works out for you buddy. Joe
- Krusty_47
28 Mar 2011 22:03Ok so a half inch off to the right isn't going to be a big issue then? If so then that's what I will do. I can modify the swingarm to fit and hopefully it won't be bad. I would love to move it maybe a bit further to make sure there is clearance for the chain and less of an offset for the sprocket.
Just so you know this is the first bike I've ridden and modified so I'm unsure of what modifications will change the handeling. I've been doing tons of researching and I want to make sure I do it right. First and foremost I want to make sure its safe to ride. After that I want it to ride and handle well. And lastly I want it to look good and be a bike I can be proud of.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
