Supercharged - injected Z1R
  • zippy
  • zippy's Avatar Topic Author
05 Aug 2009 09:44 - 05 Aug 2009 14:42
#311740
By popular demand here are some pictures and specs on my 1978 blown - injected Z1R. I'll be taking some new pictures in the following week so I will update some of these. Please excuse the flat front tire :)
1978 Blown - Injected Kawasaki Z1R Parts list
Crank Case
1. Falicon welded, balanced and magnafluxed crank
2. Manley steel crank main bearing brace and heavy duty bearing bolt kit
3. Heavy duty crank case bolt kit
4. Chrome oil pan with special oil flow gate
5. Oil windage tray
6. Custom fabricated polished oil breather with multiple outlets with braided stainless steel lines
7. Polished alternator cover
8. PMFR clutch release system
9. Falicon undercut transmission gears
10. Over shift limiter bushing
11. APE cam chain tensioner
12. Complete stainless steel allen bolt kit for all covers
Cylinder Block
1. MTC big block - copper O- ringed
2. MTC 1500cc 8.5:1 compression ratio blower pistons
3. MTC heavy duty blower wrist pins
4. MTC teflon wrist pin buttons
5. MTC heavy duty cylinder studs
6. FBG heavy duty cylinder stud nuts
Cylinder head
1. Blower ported head by Orient Express
2. Bronze valve guides
3. Heavy duty race valve springs
4. Teflon valve guide seals
5. Titanium valve spring retainers
6. MTC shim under buckets
7. Oversize Manley stainless steel valves
8. Slotted cam sprockets
9. Stock cams installed with 110 deg. Intake and 112 deg. exaust lobe centers - extra race cams included
10. Heavy duty cam chain
11. Manley aluminum cam cap end plugs
Clutch
1. Barnett heavy duty clutch plates
2. Barnett heavy duty clutch springs
3. MTC timkin bearing clutch pusher
Ignition and electral
1. Very trick Bill Hahn BHP H.E.I. blower ignition with special boost retard that senses blower manifold pressure
2. Heavy duty race plug wires
3. Chromed cover
4. Fast by Gast battery
Supercharger
1. Magnuson blower with teflon seals on lobes
2. Magnuson blower drive from clutch w/pullys for 8 lbs and 20 lbs boost
3. Magnuson fuel pump drive off of blower for Hilborn fuel pump
Fuel Injection system
1. Hilborn fuel injection system - S- 24 throttle body - 2 7/8 bore with metering valve
2. Hilborn PG 150 fuel pump
3. Hilborn velocity stack
4. Kinsler adjustable dial-a-jet main jetting system
5. Kinsler adjustable high speed precision bypass valve
6. Tons of Hilborn and Kinsler fuel flow pills
7. Braided stainless steel fuel lines and Russell aircraft fittings
8. Fuel pressure gauge
Oil cooler
1. Kerker oil cooler
2. Kerker oil cooler bypass valve included
3. Braided stainless steel oil lines with Russel aircraft fittings
Frame
1. 1978 Kawasaki Z1R frame and body parts w/ title
2. Raked head tube
3. Kosman heavy duty frame brace tubing kit installed
4. AVS heavy duty motor mounts and heavy duty bolt kit installed
5. Macintosh 8 inch over stock chrome moly boxed swingarm w/oversized axel pivot bolt
6. Macintosh chain gaurd
7. Italian Tarozzi rear set foot peg/pedal system
8. Heavy duty fork brace
9. Really trick Cir Cycle hollow alum. adjustable swingarm struts
10. Wheelie bars and mounting tabs
11. Manley fork lowering blocks installed in forks
Wheels
1. Performance Machine hubs front - spoked
2. Performance Machine hubs rear - spoked
3. Rims - Akront - 18 - 1.85 - 40 front Akront - 18 - 3.5 - 40 rear
4. Performance Machine aluminum rear sprocket
Brakes
1. Performance Machine 4 piston front caliper and rotor
2. Performance Machine 2 piston rear caliper, mounting plate, and rotor
3. Grimeca front master cylinder
4. Performance machine rear master cylinder
5. Braided stainless steel brake lines
6. Performance Machine chromed caliper mounting plate
Exaust system
1. Individual drag pipes with baffles - hi temp. black painted
2. Kosman heavy duty polished exaust keepers
3. Fancy chromed allen head knurled exaust nuts
Last edit: 05 Aug 2009 14:42 by zippy.
  • zippy
Re: Supercharged - injected Z1R
05 Aug 2009 09:45
#311741
picture 2
  • zippy
05 Aug 2009 09:46
#311742
picture 3
  • zippy
05 Aug 2009 09:47
#311744
picture 4
  • zippy
05 Aug 2009 09:48
#311745
picture 5
  • zippy
05 Aug 2009 09:49
#311746
picture 6
  • zippy
05 Aug 2009 09:50
#311747
picture 7
  • zippy
05 Aug 2009 09:51
#311748
picture 8
  • zippy
05 Aug 2009 09:51
#311749
picture 9
  • zippy
05 Aug 2009 09:52
#311750
picture 10
  • zippy
05 Aug 2009 09:52
#311751
picture 11
  • zippy
05 Aug 2009 10:08 - 05 Aug 2009 10:08
#311753
Last edit: 05 Aug 2009 10:08 by zippy.
