Picture whores,!! Help!!
  • lapeerray
  • lapeerray's Avatar Topic Author
29 May 2009 17:02
#294881
Ok, so, I know how much you guys like this term. I "scored" some new used forkes witch I have sandeddddddd and polishedddd. I removed the rotor, took it to work and had our engineer wright me a program for the cnc, I then drilled it like so hope you likey. my problem is when I reassemble wheele speedo hub thingy is tight and no play. Did I assemble something wrong?
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
  • lapeerray
Re: Picture whores,!! Help!!
29 May 2009 17:03
#294882
  • lapeerray
29 May 2009 17:03
#294883
  • lapeerray
29 May 2009 17:04
#294884
  • lapeerray
29 May 2009 17:05
#294885
  • lapeerray
29 May 2009 17:05
#294886
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
  • lapeerray
29 May 2009 17:15
#294891
Whats so funny,
  • lapeerray
29 May 2009 17:19
#294895
Kano, do you, Im sure you know something I dont so if you could please fill me in. I am a toolmaker not a motorcycle mechanic.
  • Old Man Rock
  • Old Man Rock's Avatar
29 May 2009 17:27 - 29 May 2009 18:01
#294898
Dude, Plummen wasn't making joke.. That's Homer Drooling over that beautiful rotor!
I don't know this hub/rotor set up but something I did learn regarding my ZX636 front tire/rim configuration... There's an arrow unknown to me at the time for direction of rotation....
I at first installed backwards and it was truly tight getting the rotor between the caliper brake pads...
I then found the service manual on line in researching I found OOPS! Meaning didn't know about an arrow on a blackened rim....
Rotated correctly, soooooooo much better... Seems theres a few mm difference... Go figure. Maybe same for your setup...
Just a thought,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 29 May 2009 18:01 by Old Man Rock.
29 May 2009 17:50
#294906
lapeerray wrote:
...new used forkes...removed the rotor...problem is when I reassemble wheele speedo hub thingy is tight and no play. Did I assemble something wrong?
Nice job on the rotor drilling! :cheer:
What is year and model of bike?
Were new used forks and new rotor exact replicas of the old forks and old rotor that weren't too tight? From exact same make and model?
Are both fork lower end caps installed correctly with arrows pointing forward and gaps at the rear with no gap at the front?
Good Luck! :)
  • lapeerray
29 May 2009 18:01
#294909
78 b2 I believe, Rotor is original, forks are a 78 something but I have rode the bike with "used new to me forks" then pulled rotor and reassembled arrows are pointing forward and gaps to rear. Oh yah OMR, kano was making ajoke not plummen:woohoo: :woohoo: :woohoo:
