Picture whores,!! Help!!
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Picture whores,!! Help!!
29 May 2009 18:03
#294911
DOh... I'm so used to the Plummen Hommer...
Kano, you thief! :laugh: :laugh:
Either way, was a compliment regardless, beautiful workmanship[....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
29 May 2009 19:42
#294930
lapeeray:
Very beautiful work on the rotor.
Presuming that the forks are identical and properly assembled, perhaps the speedometer drive unit is not assembled quite right. The gearbox that surrounds the axle has two slots inside it. The tubular collar that fits inside the rotor assembly, has two external drive ears on it that fit into the recess in the disc. On the other end there are two little ears that have to be aligned with the slots in the speedometer unit during assembly for everything to work smoothly. If not aligned, it will still go together, but everything is under such stress that the wheel may turn, but not very freely.
Another test might be to remove the brake caliper and then see if the wheel rotates freely. If it turns freely, then the forks must not be aligning the brake caliper properly with the disc.
Just my thoughts.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
  • KZ250LTD
  • KZ250LTD's Avatar
29 May 2009 22:27
#294944
And always make sure to spin the front wheel when reinserting speedo cable! Yeah, its simple but might as well make sure :p
79 KZ1000ST
Past:
Many.
  • lapeerray
  • lapeerray's Avatar Topic Author
30 May 2009 03:49
#294978
Thanks everyone for your insight, Ill be out in the garage first thing this morning. I will be riding today for its going to be a beautiful day out and my wife has to work all day:woohoo: hope she dont read these.
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
  • lapeerray
30 May 2009 06:47
#295000
Is the speedo housing supposed to move freely between speedo gear when axel is tight? :unsure:
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
30 May 2009 06:54
#295001
i havn't got a speedo drive on my bike yet,
this may help its for my bike though.
  • PLUMMEN
  • PLUMMEN's Avatar
30 May 2009 07:32
#295007
i picture whore is a 20 year old with a camera,we sir are highly trained picture sluts on this site! :laugh: anyway make sure the slots on the speedo drive are engaged with hub and dont overtighten the axle nuts pinching the hub/speedo drive.arrows on bottem of fork legs are just there to match caps with the lower legs the way they were machined B)
  • lapeerray
30 May 2009 08:13
#295012
so is the speedo hub supposed to move freely? thankyou
  • lapeerray
30 May 2009 08:17
#295015
Oh ya according to the book tighten axel nuts to 60ftlbs so any thing after that would be overtight correct.
  • WABBMW
  • WABBMW's Avatar
30 May 2009 08:51
#295023
The aluminum speedo unit has a steel tubular center to it. This becomes part of the entire assembly that is tightly clamped when the axle nut is tightened. Therefore once the axle nut is tight, then the speedo unit should be clamped tightly as well, and should not move. Before tightening the nut, position the speedo unit such that it is pointing straight toward the speedometer cable. This will prevent a bad angle for the cable housing.
Regarding the collar that inserts into the speedo unit, I prefer to manually slide the speedo unit onto the collar, then turn it until the ears engage into the slots. I do all this with the wheel resting between the forks. Once the speedo unit is properly engaged, I hold it manually into position, along with the spacers on the other side, and then carefully insert entire wheel assembly between the forks. Then slide the axle through.
Good luck.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
  • lapeerray
30 May 2009 09:48
#295042
thankyou WABBMW that is what I was looking to hear!! I dont know why but I cou;ld have sworn the speedo hub floated.
