KZ650 - 810cc
- T_Dub
Re: KZ650 - 810cc
19 May 2012 06:52
Oh we can have a comparison if I ever do change, it'd be interesting to test them side by side on a dyno to see exactly where the differences are.
Ideally, the carb I could want for my bike would be a mikuni RS30, but unfortunately they dont exist.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- T_Dub
Re: KZ650 - 810cc
19 May 2012 07:43
So I discovered something. Mikuni does make their TMR carb range for our bikes. Which means 28mm and 32mm flatslide Mikunis. They seem like they're going to be too expensive but I have a couple feelers out in Europe to see what the best price is.
So now the question. Would 28's or 32's be better on a 810?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
Re: KZ650 - 810cc
19 May 2012 11:06 - 19 May 2012 11:09
TMR's will be almost impossible to find in a racked kz set. so any size u find will be good. the size comes down to your riding style. all carbs r a compromise of some sort. the ideal carb size for low end will lack in top end. the carb needs a high vacuum signal to perform its best at low rpm's so a smaller diameter carb will perform better. at wot u have a lot of signal so the bigger carb breaths better(providing your ports can match the carbs volume).
part of the problem we face is cost and availability. i think the cr29's would be a great all around fit . but as u have found, so is the RS34. the flat slides, provides a 15% better signal at 1/4 throttle, than the same size round slide. so there shouldn’t be a huge dif down low. Which is best? depends on how u ride. i dont ride below 4000rpm, so i would choose bigger. if u r going to whack the throttle, r you likely to have the rpm's high, or low?
That’s why I say to keep the RS’s , WHILE,u try something else. That way, u can go back and forth until u decide.
The cams will also play a part in this formula. They act something like the carbs. the more duration u have, the more top end and less bottom end u will have.
So a motor with a short duration cam will accept a bigger carb with less low end loss.
There r so many ways to build a motor. U can match all the parts to top end or bottom end, and have a motor the screams at 1 end. Or you can change it up to spread the power out. It depends on your wants. Everyone is dif.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 19 May 2012 11:09 by mark1122.
- T_Dub
Re: KZ650 - 810cc
19 May 2012 11:23
Yeah I'm a lot like you. Not much time spent below 4000rpm. I found the response on the 34's just fine.
The KZ racked TMR's are available from a couple places in Europe, just waiting on a price. Probably going to be close to $2000. Which is nuts. Also got my eye on an eBay set of 33 flatslides. Might get them if they dont go too high, just as a sort of investment. If I clean them up and sort them out to work well on my 810, people will pay a good bit for them. And I cant imagine the jetting will be much different than on my 34's. Plus if they work better I'll just pawn off the 34's. But I doubt they will.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
Re: KZ650 - 810cc
19 May 2012 12:12
what r the 33's off of. the spacing will likly be wrong.
some of the old gzx 's used them, they will fit.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- T_Dub
Re: KZ650 - 810cc
19 May 2012 12:37
From a GSX750R, oil cooled. I think they're the same. Maybe a bit off. Injected on here used to have a set on a 650.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
Re: KZ650 - 810cc
19 May 2012 14:47
they would be interesting to play with. my friend has a set on his 1428 but he has so many projects, i've never seen the bike run.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- T_Dub
Re: KZ650 - 810cc
19 May 2012 14:58
Yeah they're like hens teeth though it seems. So if I get a set I'll get them working on the bike after she's broken in to see how they perform on an 810. It'll be interesting to have the comparison. Then when I win the lottery I'll get a set of TMR32's and try those. And then a set of CR29's. Put them all on the dyno and see whats what. It'd be really fun.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
Re: KZ650 - 810cc
19 May 2012 15:10
LOL :laugh: wouldnt that be the greatest.i have had the same asperations.
but lately i just think, a zx14 may be cheaper :woohoo:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- T_Dub
Re: KZ650 - 810cc
19 May 2012 15:34
Ahh, ZX14's are for little girls. Men ride KZ's. :woohoo:
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
Re: KZ650 - 810cc
19 May 2012 16:15
I get a lot of guys looking at me when i ride the KZ. :blink:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
Re: KZ650 - 810cc
20 May 2012 01:18T_Dub wrote: Ahh, ZX14's are for little girls. Men ride KZ's. :woohoo:
Ha-haaaa!!! Well said!!!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
