1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- mark1122
- Keep twisting it
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
31 Mar 2009 11:37
tk11b40 wrote:
Can u tell me what the bolt spaceing distance is ,on the mounting bolts for the master cyl?(center to center, )
Had a lotta help on this project, Stoppee, 341, the "Wizard". A fella that does the Baja 1000 on an XR suggested using a dirt bike rear brake to reduce weight.
Genious..those dam dirt bikers..
So we ordered a brand new CR450R rear brake caliper, and master cylinder.
The master cylinder has its own resevoir for fluid, so its a cleaner set-up, no tube and plastic bucket hanging out there.
The stuff looks like jewelry. I had the rotor machined to the diameter, and thickness of the stock CR rotor, and presto..about a third the wieght!!
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
01 Apr 2009 22:06
Distance center to center mounting holes for CR450
Master Cylinder=
49mm.
And hey Stoppee....
Proud pictures..??
Ahh how about a burnout photo? Airborne ??
Crashing sucks.:laugh:
Master Cylinder=
49mm.
And hey Stoppee....
Proud pictures..??
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
02 Apr 2009 12:41
Thanks. That is a great idea.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
02 Apr 2009 20:08
cherrymetal wrote:
cherrymetal,
I called Advanced Powder Coating today, they looked up the RAL number.... Prepare to copy:
Cardinal (brand)
T 358-GR539 (the silver)
Cardinal
CL01 (the clear topcoat)
hope that does you some good. I was hesitant to do silver, but they showed me a grill guard they were doing for a Pick-up truck, it looks so nice. Not loud or flashy, but very nice.
Do you know what the RAL number for the silver you had it powder coated is? It looks really nice!
cherrymetal,
Cardinal (brand)
Cardinal
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
03 Apr 2009 21:56 - 03 Apr 2009 21:58
Today I was looking for an easy project, so removed the carbs from the rack, and drilled lightiner holes, I love the old school look. Then I polished it somewhat.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Last edit: 03 Apr 2009 21:58 by tk11b40.
- mark1122
- Keep twisting it
04 Apr 2009 09:25 - 04 Apr 2009 09:29
What carbs do u have there. it looks like u could cut a lot of metal out between the carbs. Aftermarket cabs dont have any of that extra metal. Just rails that tie the carbs together.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 04 Apr 2009 09:29 by mark1122.
- tk11b40
04 Apr 2009 18:58
Hmmmm,
Thought about that, but remebered racers experimenting with heat sheilds in the early 80's, so thinking the carbs would be better sheilded from the heat this way.
What do you think?
What do you think?
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
05 Apr 2009 06:15
Thats a good point but i dont think they use full plates anymore do they? My smoothbores and RS carbs run on rails.
I guess the carbs are going to pick up heat as the plate heats up anyways, maybe more as it gets hot?
Its up to u but since u like the hole look, i cant see any big issue.
Chances are good that u will want bigger carbs latter anyways.:laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
05 Apr 2009 17:05
Have you ridden it yet? How is your gearing? What is your gearing?
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- tk11b40
05 Apr 2009 20:18
:laugh: Ridden it...
I git on it and make motor noises, I imagine it running down the corkscrew at Laguna, Eddie Lawson, Freddie Spencer pressuring me for the big mistake so they can take the lead....then my wife opens the door to the garage, with that "you are pitiful" look all over her face.
Oh yea I've ridden it..:laugh:
Actually I started it a few times, then had to take it all apart again, so i could get the frame powder coated.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
05 Apr 2009 20:27
Ok The carb plate, goes back to surgery, Think I'll bore a few more holes in the face.
Makes me think though, I had an ELR with aftermarket Mikuni 33mm smoothbores, that thing was a pig in traffic, I am wonderring if the rails, and all the heat had something to do with it.
Smoothbores, with the rails are made for racing, bike is always moving, so air runs through.
It would be real interesting to know exactly why they use an aluminum Die Cast plate in fron of the carbs, instead of rails. After all the rails would be cheaper to manufacture.
I'm gonna drill some 7/8" holes through the front.
Thanks for the input!!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- Calhoun
05 Apr 2009 21:19
So no you have not ridden it:P I like that front sprocket cover. Wish I knew what was behind it:side:
