1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- testarossa
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
26 Oct 2010 06:28
My motor weighs 210 lbs on my nuclear precision bathroom scale. I have a standard KZ1000A2 motor with a welded 900 crank. I'm pretty sure that I weighed it with the starter and carbs attached.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
26 Oct 2010 07:06
testarossa wrote:
considering the height that's chunky by any ones opinion!:dry:
- tk11b40
27 Oct 2010 18:26
dutchz wrote:
Very good info, and advice. Thank you.
I'm not sure I can get any lighter than 450. My Ducati weighs like 425, with 120 Hp. It's just the perfect combination for riding on the street or track. More power is always fun, but how often do you really open up a bike that has say over 150 HP.
Just read through the last half of your thread, great job!
Don't know if you read the reply in my thread but yes, mine weighs 450lbs with a full tank of gas, 51/49 F/R. Not bad for a steel framed bike with a lug of a motor... I forget what just the motor weighs but it's a large chunk of weight... Mark is right, it never ends... Don't get too carried away with the weight savings if you are close to your goal :whistle: You've done all the big stuff. Bike looks great!
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
27 Oct 2010 18:33
testarossa wrote:
More good info, man I hefted the motor onto a stand, it was a heavy beast, 210.
That leaves 240 for the rest of the bike.
The later motor with the porkchop crank, it must be lighter?
Which leads to the next question, I have heard you can breed the older Z-1 engine with the J model and have the best of two worlds...is that correct?
Which leads to the advice I keep getting (good advice) just get it done!!
Boy I sure want to, but the economy is making me careful about spending any amount.
Soon as I have 400 bucks set aside for the bike the ignition will be on, and it will be running. I work in a Machine shop, we are very busy so I think the worst of the recession is over.
I have to tell you all this forum is the greatest, i get stuck on a problem and just start surfing, there is someone always smart enough to figure it all out.
I would be in a real jam without all the help you guys are giving me..
Many thanks!!!
Many thanks!!!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
27 Oct 2010 18:40
larrycavan wrote:
I appreciate the advice....really. I take no offense, and certainly will be thinking about the possbility.
I actually take a great amount of care, in fact the shock mounts for instance were reverse engineered fromt the original ZRX, same size, same material (6061 Al).
The only spooky thing I think about so far is the rear brake, if it ever lets go due to a material failure, it will lock up the rear tire.
Most of the time under hard braking the rear tire is just skimming off the pavement so there is not much force involved. I rarely use it, but like to when I am not sure about surface conditions (i.e. gravel in the road).
You guys are all great, I truly appreciate the input.
TK11b40,
I'm just going to throw this out there for you...
4 days ago a guy I know with a little repair shop was riding an old CBR Honda on a test ride.
He's going down the road about 70mph, SNAP... and the ass end of the bike hits the road. Long story short he crashed and broke his foot pretty badly.
I looked at the bike yesterday. To me it looks like somebody got carried away with the rear shock mount. It was wicked light aluminum plates and they broke...ripped right through the bolt holes :ohmy: It sure didn't look like OEM bracket.
Just be careful with your build bud.... That's all I'm saying..... be careful
Not picking anything apart on your bike.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
28 Oct 2010 07:12 - 28 Oct 2010 07:15
tk11b40 wrote:
the 73 to 76 pork chop is about 8 lbs lighter than the kz,i think.the MK11 is in-between, i have a MK11 in my KZ.
the only thing desirable from the J motor would be the head. it has larger ports and valves. although it may be cheaper to convert the kz head to these specs.
the J head requires dif pistons on a kz due to the larger chamber. it also requires that u convert the cam chain tower from the J to the KZ since the chains are dif.
i think that if u were going to go to that trouble, u would be better off going right to an 84/85 gpz head. u still need to address the pistons, but in the end, u get the best head available . larger valves and ports than the J, so less money spent on those alterations.
i think the cheapest upgrade may be to put a gpz11 motor in a kz frame.
Many thanks!!!
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Oct 2010 07:15 by mark1122.
- Kidkawie
- I bleed premix
28 Oct 2010 08:43 - 28 Oct 2010 08:43
I snapped a rear brake stay on a HD I had, wasn't even going fast.
I'd use 2 heim joints and ti rod instead of that box.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 28 Oct 2010 08:43 by Kidkawie.
- 79MKII
- Love Them Kaws!
28 Oct 2010 15:33
I've never owned one but have seen cranks for sale that combined the lighter pork chop style crank with the 16 tooth heavy duty center pin from the '79 and '80 MKII motors. Not sure about the J crank....
The Kaw List:
- mark1122
- Keep twisting it
29 Oct 2010 10:05
79MKII wrote:
I think Falcon does that conversion.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
29 Oct 2010 19:30
1 finish bike....
2 license bike
3 New motor waa haaaaa haaaaha aa
Deep in the laboritory........
I want to keep the old style z motor, but the light wieght crank, porting plus one of them there humngus 1400 cc kits, and a midrange cam that will pull your arms out at 6000 rpm.
Now that would be the ultimate street motorB)
2 license bike
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- Bad Kaw
- Flying Squirell
31 Oct 2010 15:31
tk11b40 wrote:
Response: [insert 'Tim Allen'-ish man-grunt sounds]
1 finish bike....
2 license bike
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- porchev914
31 Oct 2010 17:50
mark1122 wrote:
So does Stan Gardner Racing with a Falicon center pin79MKII wrote:I've never owned one but have seen cranks for sale that combined the lighter pork chop style crank with the 16 tooth heavy duty center pin from the '79 and '80 MKII motors. Not sure about the J crank....
FRANKEN Z!
