1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- mark1122
- Keep twisting it
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
14 Aug 2009 06:30 - 14 Aug 2009 06:31
Yes that is a 630 non O Ring chain. what part is scarring u?
My 2 sprockets line up perfectly.
Next time i need a new chain i think i will Squeese the frame a bit more and get an O ring chain.
Now that u have welded the shock mounts on, u have selected your rake, haven’t u?
by moving the mounts forward or back u will raise or lower the rear end, thus adjusting the rake. i found that 1 inch change in rear height = about 1 * of rake change.
I tried to get my bike to sit level and the rake was about 27*. now that I have the shocks upright the rake is 22.5*. Too steep.
how did u determine where to place the upper and lower shock mounts?
Do u know what your spring rates are yet? or what kind of the shocks were used on last?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 14 Aug 2009 06:31 by mark1122.
- tk11b40
14 Aug 2009 22:07
mark1122 wrote:
I'll tell you, I am thinking I'll have about .040" clearance between the frame and the chain. Yours looks about like .060".
So I am thinking while looking at the photo...crap what if thats a 520?
Now I know you have a 630, so not so worried.
The rake, now the swing arm is at Eds waiting for a tig welder. I need the wheelbase to cypher the rake.
What is the exact distance from the frame mount to the rear axle on your swing arm? with that information i could cypher the rake without my swingarm.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
14 Aug 2009 22:17
So I am putting on the details drain tubes etc. and had to figure out a way to sanitize the float drain tubes.
I had a scrap chunk of urethane, drilled four holes in one end. 1 hole out the other.
I took a 1/8" drill and connected the four holes to the single one.
Slipped the float bowl drain tubes into the fitting, with a dab of silicone to seal it, then ran a single tube out the back, looks much nicer.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
14 Aug 2009 23:39
stoppee wrote:
Ahhhh Lovely memories....
low siding in turn 2 Spokane Race Park
11B40...I don't want to bring this up, as this brings up a tramatic event. But all your riding years were not smooth and trouble free. As you recall, you did have problems that one day, while leading the pack of scooters down the straight stretch at SRP! A little to hot in the turn, to many hard parts on the ground, wheels up...well you can see the results! Hope you learned that some things are not ment to turn!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- tk11b40
15 Aug 2009 00:07
531blackbanshee wrote:
Very sanitary, very nice....yes
It was an orange custom 79mkII, that I saw in a magazine in about 1982, that reaqlly got me to thinking about building one of these. The MkII, they would sell like crazy if they would just bring them out again.
If you search KZ on U tube you will find some old promo video clips of the Superbike class. I am tellin ya those guys had big Kahooooonahs, riding that kind of horsepower on old school brakes and tires.
The MkII just exemplfies that era, even more than the Eddie Lawson replica.
anddddd Salute!!
anddddd Salute!!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- KZ250LTD
15 Aug 2009 00:24
tk11b40 wrote:
I used to ride a little honda spree around town. Going around corners pivoting on only the centerstand peg at night was always a fun one :woohoo:
Bike is looking great!
79 KZ1000ST
Past:
Many.
Past:
Many.
- mark1122
- Keep twisting it
15 Aug 2009 05:24 - 15 Aug 2009 05:26
What is the exact distance from the frame mount to the rear axle on your swing arm? with that information i could cypher the rake without my swingarm.[/quote]
swing arm, axle to axle is 21 3/4"
i just put a degree indicator on the front axle to get the rake #.
It just doned on me that the bike would have to be sitting level to get an acurate #. i'm sure my garage floor is not level, so i'll have to recheck the rake #.
when i adjusted the bike to LOOK, level, i got 27* of rake ,but now i will have to recheck it.:side:
I love your little white carb tube block. Great idea.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 15 Aug 2009 05:26 by mark1122.
- gearhead119
15 Aug 2009 21:21
I know I am the new guy here but i got a bit of info for you that might intrest you. I am a zrx 1100 owner and one of the highly sought after mods to the swingarms is a bracing service. These arms... especially the 1100's had a tendency to get a bit of flex when pushed really hard. They seem a bit unsettled entering high speed corners. this mod suposadly fixes it. the 1200 wern't as bad due to the type of tubing used for the arm. Here are a few pics of a finished arm. This guy added 6 pieces... the one just to the inside of the drive chain is the most critical to get right (so the chain doesn't hit it).
I figured if you allready got the arm off and clean it would be a good time to add a few braces....
2000 Zrx1100 Turbo-220bhp/145lbs torque
1978 KZ 1000 project-in progress
- tk11b40
15 Aug 2009 23:01
gearhead119 wrote:
Stoppee has an 1100, i have ridden it and felt something simular to what you speak of oh great one.
That is something I will be looking into for sure.
Thanks!!
Thanks!!
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
- mark1122
- Keep twisting it
16 Aug 2009 05:48
I have the zrx12 arm, on my kz. I felt a huge improvment over the stock kz arm but it could use some bracing as well. there is a lot of side flex when u down shift. so u know it has to be flexing in the corners as well. Thanks for the tip.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
16 Aug 2009 09:12
tk11b40 wrote:
thats gonna be nice when its finished!So I am putting on the details drain tubes etc. and had to figure out a way to sanitize the float drain tubes.
Slipped the float bowl drain tubes into the fitting, with a dab of silicone to seal it, then ran a single tube out the back, looks much nicer.![]()
- gearhead119
16 Aug 2009 19:07
The guy that offers the bracing service on the ZRXOA website can do 1200 arms too. He actually buys extra arms to cut apart and keep the same extruded aluminum shape as the OEM stuff. I believe the 1100's are just round stock. He usually waits until ten or so guys want them done and does them all at once so you have to get your name on a list and when everything is set to go everyone sends them in. He has been hard to get ahold of lately and last I knew wanted to get out of the welding and just sell the DIY kits. I think the kit was about 225 buck? all the pieces pre cut and shaped ( and he is VERY GOOD at it!) His bracing service cost 325 for the 1100's and 350 for the 1200. included shipping and materials. Here is a pic of one of his 1200 arms. and an 1100 before welding.
