my jigsaw puzzle
  • morningwood
  • morningwood's Avatar Topic Author
my jigsaw puzzle
17 Feb 2009 17:28
#265721
I did my intro awhile back. Here is the deal. I bought a '75 Z1B and it was a roller with the motor in the frame minus the carbs in one of three boxes of parts. I went through all the boxes of parts and have most of what I need. Is there anyway to shorten screws and bolts to get the correct length?
  • l0g1c
  • l0g1c's Avatar
  • Hanging on for dear life.
Re: my jigsaw puzzle
17 Feb 2009 17:57
#265731
Not too sure on your question, but I found that Z1 sells some bolt kits for around $27. (I'm not a shill, just got one of these for my bike).
www.z1enterprises.com/detail.aspx?ID=1226
www.z1enterprises.com/detail.aspx?ID=2674
For the price, it sure beats running down bolts all the time.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
  • trianglelaguna
  • trianglelaguna's Avatar
17 Feb 2009 18:10
#265738
or say what bolts your missing if you got a idea and someone hear will maybe have em in a plie a bolts and just send you a few .....or just get a bolt kick like suggested or in a pinch find a nut that spins on a bolt perfect and hit the metric bin at any hardware store(stainless)and use your nut as a test threads.......good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • hoghaterkaw
  • hoghaterkaw's Avatar
17 Feb 2009 18:28 - 17 Feb 2009 18:53
#265747
it can be done. make sure the the thread shoulder allows the bolt to tighten the parts together before it bottoms.
Last edit: 17 Feb 2009 18:53 by hoghaterkaw.
  • MFolks
  • MFolks's Avatar
18 Feb 2009 12:08
#265923
A chop saw will work followed by using a disc sander wheel to square the end. I like to chamfer(taper) the end so the threads are not sharp. This makes it easier to start the fastener.
A source for american and metric fasteners is www.boltdepot.com and the local ACE Hardware Store(they have a good selection of fasteners).
  • morningwood
18 Feb 2009 15:56
#265963
Thanks for the help. The nearest dealer to me is 23mi one way.
  • timebomb33
  • timebomb33's Avatar
18 Feb 2009 16:16
#265967
put a nut on the threads first then cut when you remove the nut the threads will clean them selfs up then dress them up with a grinder
I THINK MY POWERBAND BROKE
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
18 Feb 2009 17:23
#266008
your avatar scares me, a little.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Feb 2009 15:55
#266868
I'll second that.:side:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
