the 74 z1 turbo project again
- PLUMMEN
Re: the 74 z1 turbo project again
26 Jan 2009 07:27 - 01 Feb 2009 07:44
Last edit: 01 Feb 2009 07:44 by PLUMMEN.
- JAILBAIT
26 Jan 2009 11:27
Frame is looking tough. All that bracing is in the works for me right now too. I am getting the grinder out tonight to start removing the "unwanted" parts off the frame and get it ready for welding.
You are in Topeka, or the bike is? You need to make a little trip on into KC and see my project.
- PLUMMEN
26 Jan 2009 12:26 - 01 Feb 2009 07:44
- JAILBAIT
26 Jan 2009 13:30
PLUMMEN wrote:
I'm Lenexa.
What size is the tubing you used on your frame? is it tube, or solid rod?
im in nebraska,frame is in the shop in topeka.im trying to get down there this weekend to get an empty motor sitting back in there to check a couple clearance issues.what part of kansas city?that covers a lot of area!:laugh:
I'm Lenexa.
- PLUMMEN
26 Jan 2009 14:10 - 01 Feb 2009 07:44
- Old Man Rock
26 Jan 2009 14:45
kawasakiman... "MAKE WITH THE BRACE KIT ALREADY"... hahahahahahahaha :laugh: :laugh: :laugh: :laugh:
Damn Plum, the bike is going to weigh in about 300 lbs heavier.... You better design two turbos on this bike, one to get it rolling from a dead stop and the other for when at top speed of 50mph....
OMR
NOTE to Thyself: OMR is now on Plummen's hit list....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mark1122
- Keep twisting it
26 Jan 2009 14:55
PLUMMEN wrote:
SWEEEET!!:woohoo:
Now thats what im talking about.Solid.
Its a good thing i cant post pics like u can. There would be some good porn going up right now. You will have to excuse me for 2 minuits while i go beat down my rod.:woohoo:
once all the welding is done then i can spend way too many hours with a die grinder dolling everything up,i might have to stick this frame in a glass box when its done its gonna be to cool to stick the bodywork back on!:laugh:the bottem of those downtube gussets are actually slid inside the downtubes and welded
SWEEEET!!:woohoo:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
26 Jan 2009 16:15 - 01 Feb 2009 07:45
Last edit: 01 Feb 2009 07:45 by PLUMMEN.
- PLUMMEN
26 Jan 2009 16:19 - 01 Feb 2009 07:38
Last edit: 01 Feb 2009 07:38 by PLUMMEN.
- racer54
26 Jan 2009 16:35
Have you tried mounting your coils since you put those braces in? Or are you moving them? Looks really tight with that brace right above the coil mount. Where else have you added bracing? Didn't you add some in V area right above the swingarm mount bolt?
- racer54
26 Jan 2009 16:36
The last picture of the swingarm bar mount is the one where it is 4" from c-c of axle and mount hole, incase you want to know.
- PLUMMEN
26 Jan 2009 16:48 - 01 Feb 2009 07:38
