the 74 z1 turbo project again
  • PLUMMEN
  • PLUMMEN's Avatar Topic Author
Re: the 74 z1 turbo project again
23 Jan 2009 16:04 - 01 Feb 2009 07:47
#259722
Last edit: 01 Feb 2009 07:47 by PLUMMEN.
  • PLUMMEN
24 Jan 2009 16:30 - 01 Feb 2009 07:47
#259961
  • racer54
  • racer54's Avatar
25 Jan 2009 11:42
#260086
Exactly what dimensions are you looking for? I have a double clubfoot with the lower wheelie bar mounts.
  • PLUMMEN
25 Jan 2009 12:01 - 01 Feb 2009 07:48
#260090
Last edit: 01 Feb 2009 07:48 by PLUMMEN.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Jan 2009 12:07 - 25 Jan 2009 12:09
#260092
PLUMMEN wrote:
theres going to be tubing braces running from bottem of steering head following the origional stamped gusset under steering head to the downtubes to about 3" below where current gusset is cut off
You are doing a bang up job there Plum.
That bracing should make a big dif. My 1327cc bike felt like a slinky when i put it through the gears hard (even with bracing). I cant imagine what your turbo must have felt like? :woohoo:
Just a thought. I had trouble with the tank fitment, interfering with the braces. if u haven’t checked already, u may want to test fit the tank.
What do u think about some more bracing under the top rail in front of the seat? I saw it on a Sanctuary bike , and thought it was a good idea? You have every brace i have ever seen except that 1. Have u seen that Sanctuary add?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 Jan 2009 12:09 by mark1122.
  • PLUMMEN
25 Jan 2009 12:10 - 01 Feb 2009 07:48
#260095
  • racer54
  • racer54's Avatar
25 Jan 2009 16:04
#260140
I had problems with the tank fitting on the frame after I put bracing in that area too. I had to "persuade" the brace to allow the tank to fit better! Good idea to check that before you paint. As far as the c-c measurements, usually wheelie bars are built to fit each set-up. I measured three arms I have and they had 4",6 1/2" and 7" c-c measurements. I know the dragbike has the 6 1/2" c-c and the bars for that bike will only work for that bike. Pingel bars are adjustable, to a point, to fit different set-ups though. You can either build your bars to fit your set-up or buy some bars and weld the mounts so they fit those bars. Every bike is different. My dragbike mounts are under the rear axle and one arm has the mounts about 6" in front of the axle. Why do you need wheelie bars? You're not going to run sissy bars are ya? Training wheels on that turbo? LOL
  • PLUMMEN
25 Jan 2009 16:13 - 01 Feb 2009 07:49
#260142
Last edit: 01 Feb 2009 07:49 by PLUMMEN.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
25 Jan 2009 17:15 - 25 Jan 2009 17:19
#260164
I bought precut brackets from Pingel and had them welded onto the bottom of my swingarm. I also had struts made with a small bracket only at the bottom of the strut. I really worked out well. Most bars are adjustable so you should have some wiggle room.
I'll add some pictures of my old set up if I can find them.
OK, here's a shot of the swingarm bracket, but not the struts. The arm is gone so I can't offer a measurement, sorry!
The Kaw List:
Last edit: 25 Jan 2009 17:19 by 79MKII.
  • PLUMMEN
25 Jan 2009 17:21 - 01 Feb 2009 07:49
#260165
  • racer54
  • racer54's Avatar
25 Jan 2009 18:04 - 25 Jan 2009 18:10
#260174
Here are a couple pictures of mounts on the arms I have. D&G Chassis also sells mounts but I don't know what they look like. I know all their work is top quality though.
Last edit: 25 Jan 2009 18:10 by racer54.
  • racer54
  • racer54's Avatar
25 Jan 2009 18:11
#260177
Another...
