KZ400 cafe with a touch of class...
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
Re: KZ400 cafe with a touch of class...
11 Dec 2008 15:26 - 11 Dec 2008 15:33
#252035
Fabrication's half the fun!
Here's what I did:
kzrider.com/index.php?option=com_kunena&...96297&catid=5#171984
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Last edit: 11 Dec 2008 15:33 by guitargeek.
  • valvesprung
  • valvesprung's Avatar Topic Author
11 Dec 2008 18:52 - 11 Dec 2008 18:54
#252091
Well I finally took her over to see a professional, hopefully I'll know what the problem is tomorrow...
Her transportation for the ride over:
Jordan Green
HM Motorsports
Last edit: 11 Dec 2008 18:54 by valvesprung.
  • cafekz750
  • cafekz750's Avatar
12 Dec 2008 10:37 - 12 Dec 2008 10:39
#252221
guitargeek wrote:
Wildh2oskier wrote:
Not bad looking for a cliche racer. :)
Wow... that NEVER gets old. Not everyone wants to look like Fonzie on a Hardley wannabe cruiser.
Thanks for the laugh GG.
valvesprung, that's a pretty bike you got there. Any plans for rearsets? I highly recommend them if you're going for a lower handlebar, even a superbike bend.
I have to echo the rearsets with dropped bars.
Great looking bike.B)
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Last edit: 12 Dec 2008 10:39 by cafekz750.
  • HerrDeacon
  • HerrDeacon's Avatar
12 Dec 2008 16:23
#252257
What did you guys do for rearsets? Fab your own? Sportbike? I have clubmans and I'm still using the stock position, I find it comfortable but would like to get rearsets down the road.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Dec 2008 08:25 - 13 Dec 2008 08:33
#252355
I have '04 GSXR600 rearsets on my '78 650.
My '78 C model had the one bolt mount front footpegs, as did '77 B & C models.
D model 650s came with two bolt mount front pegs.
On the 650s with the two bolt mounts, you can swap the mounts left side to right and vice versa.
The pegs need to be swapped back to their right side if I remember correctly.
This will move the pegs further back.
You will need to shorten your brake lever, and rig up a gear changer set up.
Here is Guitargeek's set up again:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 13 Dec 2008 08:33 by rstnick.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Dec 2008 08:26
#252356
another angle:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Dec 2008 08:28
#252357
Brake side:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Dec 2008 08:31
#252358
I have Clubman bars, and rode for a few years with a stock peg positon.
It seemed fine.
I then switched to the GSXR pegs and like the feel of them.
It moved the pegs back about 5~6 inches:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • HerrDeacon
13 Dec 2008 12:42 - 13 Dec 2008 12:43
#252384
Thansk rstnick, great pics. Doesn't look too bad of an install. To mount, you just needed to drill two holes on each side?
Also, you are using the rear master cylinder from the GSXR? Pretty neat. Any particular year GSXR?
Last edit: 13 Dec 2008 12:43 by HerrDeacon.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Dec 2008 20:07 - 13 Dec 2008 20:15
#252461
If your pegs are a two bolt mount, mounting aftermaket rearsets would be different than mine.
On my install, I just drilled the two holes on each side, and needed to grind the stock M/C mount for clearance.
They are '04 GSXR600 mounts with blue aftermarket pegs. Similar ZX, YZ and other year GXSR set ups could work.
I used the GSXR MC and brake light switch.
Here's a link to a post with some different rearset set ups:
Rear sets
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 13 Dec 2008 20:15 by rstnick.
  • HerrDeacon
14 Dec 2008 02:30
#252506
Excellent, thanks again, great help.
  • valvesprung
28 Jan 2009 19:54
#260763
Cycle Metrics rocks if anyone in the Portland area needs help. While it was there he also totally readjusted the carbs, lubed all of the cables, adjusted the front brake after replacement, adjusted the clutch (which included straightening the bent clutch lever), replaced the turn signal flasher with on that works with my smaller lights, and redid several sections of wiring that needed attention, all this for the price he'd quoted for the stator/charging system repair!
With cold wet roads I only got out for a brief ride, but it was heaven. This bike has never ridden this well in any aspect. The new bars were perfect, the power was great, the bloody turn signals worked...I wasn't worried about it dying...it was a good f@#king day my friends...a good day indeed...
All that is left is some fresh paint on the new stator cover, a new battery, and a full tank of fresh gas and she'll be road worthy at the first sign of sun...
Jordan Green
HM Motorsports
