Z1 powered '81 Moto Martin
  • Robinjo
  • Robinjo's Avatar Topic Author
Re: Z1 powered '81 Moto Martin
05 Mar 2009 12:14
#269838
Bad Kaw wrote:
:whistle:
I've been temporarily defeated by the front brake, can't seem to get it bled properly, even tried a different master cilinder but that didn't help... bled a lot of brakes but this one is a toughie, maybe a big siringe or a vacuum pump might work.
Moto Martin Z900 1981/73 engine
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
05 Mar 2009 12:24
#269841
here at work(toyota forklift dealership)we up bleed brakes from the wheel cylinder,block the master cylinder open and pressure up in to the reservore(sp?)until you see no bubbles and clean fluid.we use squirt oil cans with a vacuum hose wired on the end to connect to the bleeder with brake fluid in it to do it. hth
leon holmes
  • 531blackbanshee
  • Vendor
  • Vendor
05 Mar 2009 12:25
#269842
oh yeah,so i guess "no windmill pics"eh?haha
:laugh:
leon holmes
  • Robinjo
05 Mar 2009 13:09
#269854
Oh there will be pics, with or without a windmill/ coffeeshop/red light district/tulip field background (choose your favorite Dutch cliche)... but not today.
  • 531blackbanshee
  • Vendor
  • Vendor
05 Mar 2009 13:44
#269856
we understand that the bikes are the priority.without them we would all be a bunch of un-connected village idiots,wait someone with a pitchfork is calling me!:laugh:
leon holmes
  • Robinjo
08 Mar 2009 10:35
#270373
There you go! :cheer:
An actual working windmill, used to grind grane for the baker next door to it, pretty windy outside today so it was spinning fast. Kinda dwarfs the mighty Martin though. :blush:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
08 Mar 2009 10:51
#270377
Pretty Cool.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • Vendor
  • Vendor
09 Mar 2009 07:44
#270571
naw,the martin looks like david fixing to topple goliath!
ok funny guy,thanks for the obligatory windmill picture,:laugh: .so what kinda 90 degree drive do those windmills use?bevel drive,flat plates with interlocking pins or what?got any idea?i truely am a gear head even if they aren't on bikes:P .
didja get your brakes bled out?
sorry for all the questions,but i need to know things:lol: .
leon holmes
  • Robinjo
09 Mar 2009 13:59 - 09 Mar 2009 14:01
#270633
leon holmes
I finally got the brakes bled, sort of.
Turns out one of the botttom exits of the brakeline splitter had an 'issue' (learned that from OCC :laugh: ) and was filed down flat again but at a few degrees angle, solved by really bolting the banjo down tightly squishing the sealer washer to twice it's normal width at one end, when I replaced it with a new one without knowing what was going on down there it kept leaking. I resurfaced the entire bottom end of the splitter so it's all straight again. Also there some air still trapped in there so ended up unbolting it from the lower tree and keeping it at and angle during bleeding and leaving it a day under pressure got me some pressure, not perfect but enough for a testrun. Could have acces to a vacuum system soon hopefully.
Is this a stock Kawa splitter?
Test run this saturday at the Open house day of Moto Eemnes, weather permitting.
Windmill gears are usually flat plates with interlocking pins afaik, wooden off course.
Last edit: 09 Mar 2009 14:01 by Robinjo.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
09 Mar 2009 14:37
#270650
That is an early single disk splitter. it will work fine.I used 1 like that. the dual disks, had a similar splitter with another outlet.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • Vendor
  • Vendor
13 Mar 2009 13:57
#271636
brakes are a good thing,mostly:laugh: .although they are always the last thing i wan't to use:P .flat plates with interlocking pins eh?just as i suspected.
i hope you got your bike lined out for the moto Eemnes.keep us posted.
leon holmes
  • Robinjo
13 Mar 2009 14:24
#271646
This is the splitter that was on my dual disc bike, there are two outlets on the bottom, you can see that one was filed down (crooked) allways good to know if a part is stock or not on a special bike like this.
leon holmes
He who brakes later rides fast longer right? ;)
Brakes are about right now, did some more bleeding and left it standing under pressure for a night ad I got some pressure without pumping, after another night the lever is a bit firmer still, shaved down brake pads still need some running in too I guess so that should help.
Also entered the bike for the "1st Int. Dutch Classic
Superbike Meeting" in June I told you about a while ago and it's accepted. :) Check out the contestants foto gallery! www.classicsuperbikemeeting.nl/english/english.htm
But right now I lost the clutch, all of a sudden it's slipping and can't be adjusted properly, the feel in the lever is weird. :unsure: Checked a lot of stuff also inside the motor but that looks okay except two broken fiber plates, maybe it's the bit of galling on the cluth rod or maybe the worm gear is the issue. will do a search here for the common causes.
