Paint or Project Dont matter
  • kzwolfsr
  • kzwolfsr's Avatar Topic Author
08 Jan 2007 17:51
#104316
I seen some spray paint in Napa That I would like to use on my ugly, rusty headers. The label says it contains ceramics which could be a good sign and it can handle heat as high as 1200 degrees. What do you think of that? What other brands and where did you guys get them and how long did they last?. I think I am gonna get the spray paint from there, but which color I dont know. Probably just black till I find out what I will paint my bike in, which color?
Original man of the Caribbean
  • pumps
  • pumps's Avatar
Re: Paint or Project Dont matter
08 Jan 2007 19:58
#104357
I've heard of bbq grill paint too, but your idea sounds as good as any other. Can you get the rust off as much as you can? Wire wheel or sand them? Down to some decent metal? There was some stuff by permatex ..rust remover someone mentioned that worked swell. THEN they painted.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • donthekawguy
  • donthekawguy's Avatar
08 Jan 2007 21:09
#104386
I use BBQ paint about two years ago and they still look pretty good. I'm getting a sidewinder soon so I won't have to paint again! B)
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • kzwolfsr
08 Jan 2007 21:13
#104388
Thanks for the tips! So if I buy this ceramic spray paint I should be in better hands than BBQ!
  • wireman
  • wireman's Avatar
09 Jan 2007 01:42
#104405
the surface prep is the main thing,sandblast your header;)
  • 81Red750
  • 81Red750's Avatar
09 Jan 2007 05:01
#104409
to mirror and add. I've used the Duplicolor Ceramic with great results and longevity. the trick is 2 fold:
1. prep right - media blast if possible
2. oven bake the parts. Dont tell the wife, but bake the painted items by the directions on the can (I think its 300* for 20 minutes, but its been a while). It will stink a little bit
the oven baking really gets the paint cured and resilient.
  • ltdrider
  • ltdrider's Avatar
09 Jan 2007 06:32
#104417
Here's what my pipes looked like when I pulled them off my Voyager:
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • ltdrider
  • ltdrider's Avatar
09 Jan 2007 06:33
#104418
After sandblasting:
Greensboro, NC
  • ltdrider
  • ltdrider's Avatar
09 Jan 2007 06:35
#104419
And after painting.
I used Duplicolor High Temp for Exhaust Pipes. Your choice of color is Black or Silver. I didn't bake the pipes before I installed them. I guess they'll get baked when I run the motor.
Greensboro, NC
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
09 Jan 2007 07:07
#104422
Looks good ltdrider.
Here's yet one more option.
Eastwood sells this exhaust manifold paint: www.eastwoodco.com/jump.jsp?itemID=733&itemType=PRODUCT
I used it on a Honda 750. Lasts a long time. I sand blasted the header first. Then I just painted the stuff on with a brush. It flowed out real well. Then I hung it up over a kerosene heater to help it cure.
It's kinda unique color too. You'll be the only one on the block with a cast iron 4 into 1.
But nowadays, I just use BBQ black. I just make a semi-annual routine out of scrubbing down the down pipes with beartex, and spray painting them. I just use rags to mask off areas as I go. I also scrub out them rusty areas between the ears of those exhaust rings, then dab some high temp silver in with a Q-tip.
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
09 Jan 2007 07:17
#104426
My can says "300 for 20 min, 400 for 20 min, 500 for 20 min."
And if you can fit your pipes in the oven, you've got a bigger oven than I do.
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • kzwolfsr
10 Jan 2007 18:33
#104832
Good tips Riverroad anad Ltdrider. I dont think I will get to sandblast or bake but I will do the best I can do.
