Paint or Project Dont matter
- 81Red750
Re: Paint or Project Dont matter
18 Jan 2007 11:38
pstrbrc wrote:
I just did SBC 302 Exhaust manifolds, so it wasnt quote like our pipes81Red750 wrote:to mirror and add. I've used the Duplicolor Ceramic with great results and longevity. the trick is 2 fold:
1. prep right - media blast if possible
2. oven bake the parts. Dont tell the wife, but bake the painted items by the directions on the can (I think its 300* for 20 minutes, but its been a while). It will stink a little bit
the oven baking really gets the paint cured and resilient.
My can says "300 for 20 min, 400 for 20 min, 500 for 20 min."
And if you can fit your pipes in the oven, you've got a bigger oven than I do.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
18 Jan 2007 12:09
I'm going to use Bar-B-Q grill paint its cheaper and harder you can leave your exhaust is the sun let it get hot then spray let them dry and put them on.
- chetriply
18 Jan 2007 13:00
If you have a heat gun, use it to cure the pipes. I've done it several times on customers bikes and no complaints. You can even use a propane plumbers torch. Just don't boil the paint (easy to do).
- kzwolfsr
19 Jan 2007 06:43
Why not let the exhaust heat itself up and bake the pipes itself?
Original man of the Caribbean
- chetriply
19 Jan 2007 07:40
It will work to a certain extent. However, you're not getting an even heat to the surface. I know that a heat gun or a torch isn't the best, but it will do in a pinch.
- stone_cold
21 Jan 2007 08:38
On our race cars we just fire the engine up and then kill it as the headers just start to smoke. We cycle it that way 4 or 5 times allowing them to cool after each heating. That has worked really well for us.
I have used a couple of heat lamps and a foil tent to make a mini heat oven for some cast manifolds for a pulling tractor (it worked pretty well).
I was a mechanic for a VW dealer back 25 years ago. We would use a 100 watt light bulb in a shop light to make an oven in the bottom drawer of my tool box (white trash Easy Bake Oven). There is no telling how many meals we've made or reheated using that method
Just my 2 cents worth on a rainy cold Sunday. It worked for me.
Tony T
Tony T
- kzwolfsr
21 Jan 2007 15:13
Thanks Stone Cold! That was interesting, now I know what to do.
- stone_cold
22 Jan 2007 05:17
Just a quick word of caution. The pipes will heat really quick in the bend where they come out of the head; let that area be your guide not the lower part of the pipe. The bend will be really hot and the area just before the muffler may not even be warm to the touch.
Good Luck,
Tony T
Good Luck,
Tony T
